CA comeplete 1jz single turbo swap with w58 trans
Hey guys, I have complete 1jz swap forsale. This motor was swapped into my sc300 around January with fresh seal all around, and the single turbo swap was done around march last year. The car was my daily up until it was rear ended this past September. The motor is in great condition and has seen regular oil changed every 3,000 miles. The motor has seen a couple track days and help up great, and has never seen over 10psi of boost. The only reason I'm selling it is to fund my new chassis and get it on the road. I am asking 3700 for the complete swap including the motor, turbo kit, jdm 2jzgte ecu, 440cc injectors, engine harness that was done correctly(Kaizen Motorsports), w58 trans with spec stage 3 clutch, pretty much a plug and play swap minus the clutch pedals, and master cylinder.
Turbo setup is a t67 cx racing turbo(front cover was modified with a cast 90 to fit in engine bay) , cxracing newer style 1jz manifold, driftmotion 50mm wastegate. Braided stainless steel lines man at G&J in Ontario.
If you are interested, please give me a call or text at 808 238 7513
Matt300ZXT
Performance & Maintenance
21
12-15-11 11:52 AM
FormosaSC
51
08-04-08 07:20 AM
