CA FS: W58 Transmission, SoCal
Selling a W58 transmission with slave cylinder, master cylinder, SC300 clutch hard lines, W58 front half drive shaft, Competition Clutch 10lb flywheel, and Competition Clutch Stage 2 clutch/pressure plate combo. I do not know the mileage on the transmission. It was on my NA 2JZ with no issues when I had it on my car for the past 2 years.
-Transmission has a slight whine since the first day it was in my car but it still drives and shifts very smoothly.
-The master cylinder is dirty, may need to clean it out or rebuild it and do a bench bleed while you're at it.
-Slave cylinder was bought brand new when I first installed the transmission and still in very good condition.
-Clutch hard lines are in good condition with no wear. Previous owner of the W58 bought these brand new when he installed the transmission in his car.
-Flywheel was installed last year and has about 12k miles on it. I would resurface it because there is a lot of hot spots on it from when I went drag racing at The Pursuit.
-Clutch has plenty of material on it and was installed the same time as the flywheel.
-Pressure plate has hot spots all over it too. It held fine on stock NA power output for daily driving and for the occasional canyon drives. Up to you if you want to replace it or run it as is.
-Carrier bearing for the front drive shaft still spins freely and rubber looks like it's in good condition.
SOLD
Asking $500 for everything. Local pick up in SoCal (Walnut/Pomona area) only. Will not ship and prefer to sell everything together. PM me for quickest response.
I also have a spare 13lb Competiton Clutch flywheel that's brand new. Asking $200 FIRM.
20140926_175847 by blisiono, on Flickr
20140926_175905 by blisiono, on Flickr
20140926_175914 by blisiono, on Flickr
20140926_175931 by blisiono, on Flickr
20140926_175939 by blisiono, on Flickr
20140926_175948 by blisiono, on Flickr
If there are any additional pictures you are looking for, please let me know.
SOLD
![](https://farm4.staticflickr.com/3920/15374015711_3b8604ca1f_b.jpg)
![](https://farm3.staticflickr.com/2949/15190594338_3a61e4effc_b.jpg)
![](https://farm3.staticflickr.com/2943/15354182566_72940130b6_b.jpg)
![](https://farm3.staticflickr.com/2946/15377173035_3014c23667_b.jpg)
![](https://farm4.staticflickr.com/3908/15190679117_a54e61f145_b.jpg)
![](https://farm4.staticflickr.com/3907/15190592648_1073426db2_b.jpg)
First post here, signed up looking for exactly this. If you were in Houston I'd be leaving the office to snag this right now.
Out of curiosity, is the transmission originally from an SC?
On a side note, all PM's replied.
As far as I know, this originally came from a 92-94 SC and if it didn't, then probably from a MkIV of the same years. The shifter housing doesn't look like it's been opened before either, so most likely the housing and shifter linkage hasn't been swapped.
DONT SLEEP
SC400 / 300 Classifieds
12
10-08-14 12:46 PM
