turbo kit 1uz ... w58 kit swap
So i was thinking about selling my turbo kit for non vvti 1uz because i cant pass co. Emmissions who would be interested.... It would be the whole thing...the headers will adapt t3 or t4 bolt design headers murge into 1 then the turbo flange you can separate the headers and the exhaust doughnut is from the catalatic to header stock exhaust, Sub oil pan with fitting for return line, i.c. and plumbing, aem fic8 315cc injectors, turbo t3/t4 built bored and changed the compressor housing and shaft ar 50 hot side ar 75 cold side no shaft play awsome turbo boosts at 8psi at 2300 rpm, feed and return lines, the adapter to your stock oil filter housing, 8 lbs wastegate, hks bov boost controler, down pipe it goes under the the front of the car, walbro 255lph fule pump, adjustible FPR... Just not the guages i kinda built them in to the car... Requires a.c. delete, Electric fan conversion, 2 holes cut in some sheet metal also your stock sub oil pan and plug from the oil adapter housing $4500
W58 to 1uz...would be the transmission and swan shifter shifter **** 120k mi on trans...,15k mi on these parts 4 puck kevlar clutch disk, 8500 clamp force pressure plate, custome flywheel, master cylinder, slave cylinder, custome lines, clutch pedal and brake pedal, drive shaft, trans mount, bellhousing, the adapter plates for bellhousing and throughout the shifter bezel, shifter, shift ****, clutch start switch connector and wire... $3000
The car is running and still together so test drive can be done and inspection i say possibly because i want what's posted for prices or i can just leave the car as a running running because it has no problems i just want to go a different route
And im saying possibly because i dont want low balled i want what the price is set ubove or i can nust leave it together as the car is running right now with no problems
Nova
SC400 / 300 Classifieds
19
01-02-17 08:32 AM
