Driftmotion r154 mount kit and Marlin Crawler VSS Adapter
Up for sale I have a complete Driftmotion r154 transmission mount kit for SC's and a Marlin Crawler VSS adapter for r154 in SC's.
Driftmotion r154 transmission mount kit - $75 SHIPPED*
This kit is essential if you are going to swap an mk3 r154 into your sc. Comes with all hardware necessary. All you have to do is drill holes in your factory crossmember. Has about 1000 miles on it. This kit also works if you want to use an mk3 supra w58 in your SC.
Marlin Crawler VSS Adapter - $35 SHIPPED*
You will need one of these if you are swapping an mk3 r154 into your SC, in order to make the speedometer work. Has about 1000 miles on it only. This is also necessary if you are using an mk3 supra w58 in your SC.
