CO 550cc 2jz fuel injectors oem
I bought these 550cc injectors originally to run Na-T with an aftermarket ecu but I ended up going with the TT ecu mod and am running 440s... The car runs great and i don't have any plans of upping boost high enough to need bigger injectors until i get a lot of things like better brakes, lsd, boost controllers or even other ecu stuff.
I got theses for 419 dollars from 5omotorsports. I'm willing to part with them for 300 shipped obo. if you have questions or want more pictures Contact me here or by email at Rmartinezpga@gmail.com or by phone 305-710-8308. Phone being the fastest way to get in touch
Brand: Denso/Custom Fiveo
Fuel Injectors Specifications:
Injector type: Saturated, high impedance
Fuel nozzle: Multi-and single-hole disc, wide spray pattern
Coil Resistance: 12.5 Ohms
Body Design: Plastic composite
Flow rates available:
3.0 BAR (43.5 psi): 380cc/min to 1400cc/min
Flow matched sets:
Will maintain linear consistency to within 1.0%
Excellent pulse-width and predictability down to 1.3-1.7 ms for easy tuning and accurate compensations.
Length: 74 mm, overall, 64 mm o-ring to o-ring
Body Diameter: 24.3 mm
O-rings: Top - 12 mm OD; Bottom - 12 mm OD
Electrical connector type: Sumitomo
Flow matched sets:
6SOARER
SC400 / 300 Classifieds
09-09-13 09:16 PM
SC300T
Performance & Maintenance
18
09-24-02 09:53 PM
