FL 2jzgte to SC300 harness (1998-2000 models)
03-07-17 | 02:17 AM
03-21-17 | 05:38 PM
Bump.....still available.
04-08-17 | 05:14 PM
OP - I would suggest that you specify if if it is for a manual or auto trans 2jzgte swap so every one is informed and there are no mis-understandings.
All 1998-2000 SC300 have auto transmissions thus their under dash wirings were for that setup .
04-10-17 | 05:24 PM
Quote:
Originally Posted by
gerrb
Thanks its for a manual R154 setup and had PTE injector plugs.
*Original post updated*
05-12-17 | 10:24 AM
07-14-17 | 01:42 PM
Bump....Still available NEW Price $500 shipped
08-03-17 | 08:20 AM
Bump obo....need to clear out space.
08-24-17 | 11:17 AM
09-15-17 | 01:09 PM
Is this plug and play to hook up to a stock ECU?
09-15-17 | 06:48 PM
mr_mkelly
Yes it will plug up to the stock ecu...On the first pic you can see the big yellow plugs that connect to the ecu.
09-26-17 | 07:07 AM
Was this an Aristo harness with the auto transmission section removed? I know you said this was set up for R154 but I just wanted to know if I can have it modded to run the A340E auto.
09-27-17 | 11:53 PM
screaminsc
The A340 trans plug should still be on there, I will comfirm the trans plug tommorow
10-06-17 | 10:53 AM
Transmission plug
Any luck finding out if the auto plug is still on the harness?
10-08-17 | 04:28 PM
screaminsc
Sorry I was over seas, I will check with my wire guy tomm.
10-10-17 | 10:26 PM
screaminsc
Ok, I comfirmed today and it has the wiring modified for the R154 electronic speed sensor and reverse light. So this will only work on a manual setup.
