NC 2jz-GTE VVTi Aristo Motor Part-out
The first thing I bought when I was starting my SC300 project was a 2JZ-GTE imported from an Aristo…as its turned out I have upgraded or changed a lot of the parts along the way to support my build goals. All the below parts some from a JDM Aristo 2JZ-GTE motor set. If there is a part you are looking for but not listed, ask and I’ll see if I have it. Pictures will be up soon, or PM me with your phone number and I can text them to you. Prices are OBO without shipping. Local pickup available in Raleigh, NC:
· Short block ($800) – block, crank, pistons, and rods. Good if you want a core engine to have built, or install it as is. Everything on this block looks really healthy.
· Twin Turbo setup ($200) – complete! All turbos, intake pipes, manifold, actuators, etc. Perfect if you want to have them built by Driftmotion and go for the sleeper look with over 500 HP: http://www.driftmotion.com/2JZ-GTE-A...e-p/dm1075.htm
· Fuel rail & Injectors – ($50)
· Coil packs (x3) – ($100)
· Aristo ECU 89661-3A470 - Non-immobilizer version: ($175)
· Spark plug cover – SOLD
· Aristo oil front sump oil pan (upper & lower), baffle plate, and oil pickup: ($100)
· Igniter – ($50)
· Intake manifold – upper & lower runners ($150)
· Throttle body – SOLD
· Igniter – ($50)
LexLova
Performance
08-13-17 06:03 AM
bmc6600
SC400 / 300 Classifieds
03-23-07 05:14 PM
