FL fs exedy hyper series twin disk clutch for r154
I have a used exedy hyper twin disk currently in my car . Ive had this clutch since 2014 and had 600rwhp and almost 500trq running thru it . No launches whatsoever and no drag racing and very little Hwy pulls on it.
Setup is around 2k give or take . Clutch will need replacement disks which are readily available for around 550 to 595 approx. This clutch is a dream to street drive . I can literally move car in 1st gear or reverse without even revving a..it shifts very well into high rpm . I personally need to move to higher holding clutch for I will be re doing my setup in the near future with new bottomend , fresh head work , newer 6466 and e85 so will be in the 700hp range .
For someone planning on running 450 to just under 600 on a r154 and want to protect their r154 and want a smooth engaging clutch , this exedy is for you
Price .. 750 plus shipping . Comes with all parts and flywheel ..
(no actual pics as yet as unit is still in car , if You are interested , you can pay for it , ill remove it , snap all actual pics so you can see full condition and if theirs something that is wrong upon inspection via pics that is verified , ill refund the money . My feedback score and dozens and dozens of high end parts I've sold speak for itself)
Link for replacement disk ,
So to my r154 users , nobody wants a solid twin disk clutch setup designed to protect the delicate tendencies of the r154 by absorbing a lot of the driveline shock . This clutch by far is one of my favorites and I've experienced most others . Stock like pedal feel and no noise and easy to drive . I'm still driving on it so disks are not completely worn . EACH DISK IS SPRUNG NOT SOLID TO ACHIEVE MAXIMUM DRIVELINE SHOCK PROTECTION
I need to order my replacement to be able to move into the 700rwhp range so ill accept in the 500 range .. with new disks you have 2k clutch for almost half the price and again I can throw in a brand new slave I mounted when I installed the clutch and a custom clutch line and fitting that eliminates the rubber line giving the clutch a even nicer feel
i had over a dozen tire kickers but no money as yet so still available
ill take any reasonable offer at this point . gents , this is a outstanding clutch for those who are on a r154 and want to preserve and prevent it from being destroyed . all it needs is 2 replacement disks which are avail on amazon for 304 each . the clutch will hold upto around 650 rwhp and close to 550 torque and is truly a dream to drive and slip with minimal chatter . the disks are sprung disks.
i have toyed with the notation of just keeping it and keeping my power where im at but i really have plans for 700 ish on flex fuel and need to goto a os giken twin which is costing me well over 2000.000
again any reasonable offer is accepted
emoFTW
Performance & Maintenance
16
06-16-13 06:34 PM
