SC430 Seatbelt Cleaning
For those that have lightly colored (Ecru) seatbelts that need to be washed and cleaned, this is what I did without removing the seatbelts. Takes about 25 minutes to prepare, wash and clean.
1. Fill half way a 15 inch tall bucket with cold water. Pour a small amount of Oxi Clean powder mixed in with liquid Tide.
2. Open car door and window where seatbelt is being worked on.
3. Fully pull out seatbelt and apply lock pliers on seatbelt where it exits the retraction housing near the C-Pillar, to prevent seatbelt from retracting.
4. Soak in seatbelt in bucket. For parts of the seatbelt that cannot reach the bucket, soak it using a sponge. Leave belt in water for appximately 5 minutes to loosen the dirt.
5. Use a 3 inch long hard bristle brush to hard scrub the belt using the palm of your hand for support to remove the dirt and stains on both sides of the seatbelt. Keep dumping brush in bucket and then reapplying the wet brush on the seatbelt to help remove hard stains.
6. After the hard cleaning is completed, dump dirty water and refill bucket with cold water to rinse the seatbelt, then use a dry towel to help dry seatbelt.
7. Close car door and lay out seatbelt outside the opened car door window to hang dry for about 3 hours.
8. Remove lock pliers to retract seatbelt.
I do not have before and after photos to share but my Ecru colored seatbelts were brought back to original condition after this cleaning procedure was completed.
3. Pull out seatbelt fully and apply lock pliers on seatbelt where the seatbelt exits the retraction housing is on the C-Pillar to prevent seatbelt from retracting.
5. Use a 3 inch long hard bristle brush and scrub belt using the palm of your hand for support to remove the dirt and stains on both sides of the seatbelt.
6. After hard cleaning is completed, dump dirty water in bucket and refill with clean cold water to rinse the seatbelt, then use a dry towel to help dry seatbelt.
7. Close car door and lay out seatbelt outside door to hang dry. Took about 3 hours for seatbelt to completely dry.
I have no before and after photos to share but my Ecru colored seatbelts were brought back to original condition after this cleaning procedure was done.
great write up…i will need to get some Oxy
Thanks. Yes, the retraction is now more natural. My driver side seatbelt was in bad shape with dirt and grime. So, yes, cleaning up the sticky grime helped improve the retraction. The cleaned seatbelt is now silky smooth and have a fresh scent too.
btw, Edited my procedure to fine tune it.
The belt receiver latch was sticking too, so i sprayed them with this, made specifically for plastic and rubber.
EleeGS
Automotive Care & Detailing
04-21-11 10:24 AM
