Rear Knuckle bushing part numbers?
What are the part numbers for the (2) rear knuckle bushings? I found the knuckle replacement but not the bushings. Also, does Figs offer a poly bushing? I need to replace the LCA and Trailing arm knuckle bushings.
Thank you in advance.
Hey Mike. I would love to help but my brain isn't working today. LOL. Can you give me a different name for the "knuckle"? I have obviously heard the term before but like I said, I don't know exactly which part it is using that terminology.
Paul
Paul
Paul,
The "knuckle" is the rear axle carrier sub assembly. The entire assembly is part number 42304-24030 (R) and 42305-24030 (L).
Regards,
Mike
Regards,
Mike
JerseyMike (05-07-23)
Thank you very much for the link / info.
Installed the PSBushings and it made a huge difference plus they were super easy to install.
Removal of the old bushings wasn't that bad. I used a Press - Pull sleeve kit which took about 30 mins per bushing including setup.
WINTOOLS 27 Pcs Universal Press & Pull Sleeve Kit Bush Bearing Removal Insertion Tool Set https://a.co/d/esi7GXH
