2001 SC430 Air-Con Compressor
Hi fellow members. I have the 2001 SC430 and the Air-Con Compressor is no longer working as it should. I thought it was going to be an easy fix by getting a new AC Compressor Mechanical Control Valve to replace, but was told that you couldn't get to mine as it's internal unlike the 2002+ models. Has anyone else had the experience?
Thank you.
Chris......From OZ.
Thank you.
Chris......From OZ.
It would be interesting to see how it is different…i would get a second opinion.
see if this thread helps…there are pics
https://www.clublexus.com/forums/sc4...-problems.html
According to mega zip…the same compressor was used on the April 2001-2004 models
Not sure he means the compressor, but the location of some of the external parts of the ac system itself. I can't remember exactly, but when my compressor went out in 2011(?), the company made me replace everything to give me a warranty for the compressor. If my mind isn't playing tricks on me, they had to go under/behind dash to get to one of the valves to replace it.
Thank you.
Chris......From OZ.
Thank you.
Chris......From OZ.
I think this may encourage me to consider getting a second opinion
tsachiti
05-30-14 05:35 AM
