My daughter was hit and car is now leaking water from left front fender, its still drivable do anyone know whats that is? and how much does it cost to fix.
Does it looks like W-W Fluid? The W-W Washer tank is on the drivers side behind the front bumper/fender. Mine was split (previous owner accident) and leaked if I filled it over a certain point. Dealer replaced it for around $400.
Yes its white liquid and only start flowing when car engine is on. Attach is video too.
that looks like green antifreeze, make sure your radiator is full and don’t start the engine until you know for sure.
You could destroy the engine if its the engine cooling system and runs empty
Thanks
Kui
It is your headlight washer. The connecting tube came off. Just reconnect it.
Can i put some water in the radiator and start the car? Also how to know if its a radiator leak.
First, can you confirm i was seeing a green/yellow liquid dripping from your car?
only use distilled water.
and yes, fill it up, if it takes a half gallon or so, you MAY have a bad leak. And should be able to see where it is coming from by looking from the top or bottom of the car.
The radiator tank will usually crack over time.
BTW, how many miles are on your 2003?
