Replacement Rims?
#31
Ok, another question on this whole wheel change topic... TPMI sensors. From what I have seen the earlier versions, 2002-2005 Have some sort of "wheel specific" sensors or something, is that correct? I know I can get the sensors on my Dodge's replaced for about $70 each at my local shop, are these Lexus TPMI units going to be a pain to deal with? $$$
I will be no help with this. I disconnected that sensor display. They were nothing but a HEADACHE for me. They didn't work when I got the car. Paid for new parts, paid to get them programmed. Then they just kept reporting issues with every weather change.
I found on here how to disconnect them and haven't looked back since. I will not buy sensors again.
#32
In fact I have an appointment to have one replaced in the wife's charger next week!
Tanker (11-15-23)
#33
I wouldn't take that gamble. If they don't fit it will be a nightmare returning them. Most likely a restocking fee.
The wheel is wider than stock and a different offset. Could lead to fitment issues. I would buy local and ask them to fit any different sized wheels on the car before you by.
Offset
35
Bolt Pattern
5x114.3
Rim Width
Offset
35
Bolt Pattern
5x114.3
Rim Width
i chose the g spiders because they are made for lexus by enkei and retain all stock specs.
i entered the wheel data into the website i linked above and it looks like that wheel with the stock tire size would poke out the wheel well a bit more and be marginally closer to the strut on the inside. no change to circumference or speedo. i don’t know if a wider tire is needed for the wider wheel. maybe someone else can answer that.
oh, and i totally agree with Tanker on TPMS. 👍
more trouble than they’re worth!
#34
Thanks, guys. Will pass on those rims. I'll keep looking and checking in as I do.
Replacement Lexus SC430 Wheels | Stock (OEM) | HH Auto (hubcaphaven.com)
- Also, check out the link below. The first set of rims are the stock ones (I think). They are the ones currently on my 2005 SC430.
#35
nzxyxy (11-27-23)
#39
#40
OK, those wheels are making me really jealous!
Can't believe my 2005 stock wheels cost so darn much.
Since I just bought my SC, I'll likely have to put pause on the checkbook for a while.
I guess my next purchase for my "baby car" will be to have the windows tinted.
Taking it to the dealer tomorrow for an oil change and check up. I'm sure they'll have a long list of things they want me to do
All the major work had been done prior to my purchase (Timing belt, water pump, serpentine belt, etc.)
Thanks for all the posts and help so far. Looking forward to keeping in touch.
-gene
-gene
#41
SGB4570
My son has that wheel on his 05 SC. They have the TRD center caps which are a ***** to find replacements for by the way.
Dennis
Dennis
#42
#43
If you like the Tourmaline's this is a MUCH better price: https://www.lexuspartsnow.com/access...30-wheels.html
#44
-gene
-gene
i tried to post some Facebook marketplace links for wheels but it didn’t work well.
take a look there, i saw plenty of wheels for sale and some decent prices
#45
Thanks for the Marketplace lead. I have been looking there from time to time. Clearly, that's the best place to find a good deal. My major problem is knowing what I can put on my car. Offset numbers and so many other numbers confuse me and make me nervous buying something that actually doesn't fit
BTW, my trip to the dealer was a pleasant experience. I went for an oil/filter change and to get my car in their system. They, as usual, they do an overall look at things they can sell me. I was pleasantly surprised that all they suggested was to have the power steering fluid changed and an alignment. I'll have those done locally since the dealership is about 1.5 hours away from me.
JDaveSC430 (11-17-23)
