Lift Supports Depot
I listened to the forum and installed the trunk struts today. What a difference! They help so much more than the old ones.
Should have done then sooner! Easy, simple, 10 minutes total, $30.
Thank you all!
Thank you all!
joemg (03-18-24)
1trkpny (03-17-24)
fishinmagi (03-30-24)
This is one of those cases where it is all about expectations.
New lift supports help keep the trunk open and stop it from falling down and bonking you on your head. They will never "Pop" the trunk open.
1trkpny (03-18-24)
I ordered new front and rear a few weeks back, haven't gotten around to it yet. Glad to see this post. The install is easy, right?
Did you guys do "Strong Arm" or the house brand? From what I understand they're basically the same, but made in different countries.
I went strong arm.
I went strong arm.
Originally Posted by DshngDaryl;[url=tel:11690139
11690139[/url]]This is one of those cases where it is all about expectations.
EDIT: wow, LSD gives all the specs right on the right, thats awesome. So these have 116lbs, not sure what OEM had.
EDIT2: Their customer service is great. They have 116lbs, 125, and 145.
for instance if you have an aftermarket spoiler that weighs more than the oem one, you could get 125lbs.
I went strong arm.
I went strong arm.
I just wanted to share my experience with LiftSupportsDepot. They're based in San Diego. I went up there today to swap out my 116lb rears with the 125lbs because i'm going to add some sound deadening and a slightly larger spoiler.
They were so nice! They even threw them on the trunk while I was there as it was drizzling. 10/10.
Note: the 125s add a lot of oomph to the opening and closing without the extra weight added. I would recommend sticking with the 116lb ones.
