New owner with key questions
Old 04-14-24 | 05:47 AM
WJudd's Avatar
WJudd
2nd gear
Default New owner with key questions
Hello,
Just bought a really nice SC430. Sweet car. The only issue is keys. Only came with one and it's not original. The remote does not work but it DOES manually open and start the car. Basically, it seems to be a valet key with useless buttons. Can I use this to start obtaining spare keys or do I have to go to the dealer?
Edit: My key does lock/unlock the glove box and storage under the arm rest. I assume this means it is programmed as a master?
Old 04-14-24 | 05:50 AM
Bgw70's Avatar
Bgw70
Originally Posted by WJudd
Hello,
yes you can but there is a limit of four keys and you may need TechStream to remove the “lost keys”
The fob is a separate programming procedure from the key
Here are some steps you can follow to attempt programming without the Toyota TechStream software
https://www.clublexus.com/forums/sc4...ramming-2.html
WJudd (04-14-24)
Old 04-14-24 | 06:11 AM
WJudd's Avatar
WJudd
2nd gear
Thanks. I'm checking that out. For a while I was afraid afraid that I was looking at pretty large dealer charges.
Old 04-14-24 | 06:17 AM
Bgw70's Avatar
Bgw70
There are plenty of threads on the key/fob programming.
Keep asking questions and searching for answers.
Welcome to Club Lexus :-)
WJudd (04-14-24)
Old 04-14-24 | 07:14 AM
SGB4570's Avatar
SGB4570
So I went through the same thing when I got my car other than I had the master key, I went to 1010 keys on ebay, they can cut you a key from a picture and then there is a series of things you can do with your key and car to program the remote, apparently it works for most people, for me it did not! It even unprogrammed my master so I ended up going to Toyota and they fixed it all making the master and the new key/remote all work fine, only a measly $175! Give it a try it might work for you without going to the dealer.
Old 04-14-24 | 10:56 AM
JDaveSC430's Avatar
JDaveSC430
checked the battery in the FOB?
Old 04-14-24 | 04:39 PM
GmanSC's Avatar
GmanSC
WJudd,
Read this thread for better understanding of your SC keys.
https://www.clublexus.com/forums/sc4...key-101-a.html
WJudd (04-14-24)
SirChunk
RX - 1st Gen (1999-2003)
10-15-21 07:54 AM
i8thesun
01-15-15 11:33 PM
clubowner
IS - 1st Gen (2001-2005)
12-11-12 12:19 AM
scdroptop
09-11-06 10:06 AM
scdroptop
09-07-06 10:45 PM
