Changed my 2002 SC430 timing belt, it's not lining up as it should
I have installed a new water pump, new 1 & 2 idlers, new timing belt, lined up the timing marks, when I turned the crankshaft using the damper bolt slowly I noticed that the belt had released from the right cam position and as if it was coming down a stair case, I now realized that I had not installed the belt tensioner.
My fear is that I have now lost the position of the both cams in relation to the crankshaft or each other.
I decided to remove the belt, realign the timing marks, re install the timing belt, install the tensioner and as per the manual, do 2 rotations of the engine TDC to TDC the timing marks will line up. The timing marks do not align.
How can I ensure that both cams are in the correct place relative to the crank?
Do I remove the cylinder head covers to check the cams?
I have beaten myself up about this, help would be greatly appreciated.
I might be wrong but bring the crank around to TDC for the number 1 cylinder and the rotate the cams to align the timing marks. At that point you should be on and can install the belt.
I am sure that someone else will chime in.
Macdog6249 (05-26-24)
LOL,
That guy is freaky, but that's a very thorough video. I don't normally watch these things but I wayched this one in it's entirety.
Excellent resource.
Excellent resource.
video: https://www.youtube.com/watch?v=VSs5...iffzillaGarage
Start watching at the 13:20 minute mark.
Thank you.
whazzzzuup
10-29-20 04:05 PM
Valencya01
Maintenance
10-30-18 08:02 AM
