Air conditioner compressor
My air conditioner button will no start the compressor. Is there anyway to run the air conditioner compressor manually. Is there a way you could add another switch to turn on the compressor. .
Chances are the system is so low on refrigerant that it won't start.
I would have someone check it.
You should run a diagnostic and pull the codes. That'll give you a start as to what is actually wrong. I would NOT go splicing wires when you don't know what the initial cause is. Condition, Cause, Correction.
doobs (06-21-24)
Did you know you can run a self diagnostic on the AC system?
https://www.clublexus.com/forums/att...iagnostics.pdf
cause=bad climate control
correction=$$$$$
that’s why I asked my question. That is the only answer I’m looking for
Sorry, that was a "cut" from my last "paste"
Here is the link to the diagnostic
bluedurama
GX - 1st Gen (2004-2009)
03-02-16 11:09 AM
mar1
09-10-11 01:31 PM
