Seat setting and radio station save during battery change
In most Toyota/Lexus vehicles, power to the power ports is cut off when the engine is turned off. Thus, a battery saver in a power port will not help. The obd device may work but I have not tried it.
I hooked a dc bench power supply to the connections when I swapped batteries.
I was surprised to see it drawing 120 mA.
I presume the battery cables. You would only need to connect the positive cable. Many positive terminals have a bolt you can tap into. The negative can be attached to any ground point.
rclab1
12-20-11 08:02 PM
