SRS light on.
Old 08-20-24 | 05:07 PM
SGB4570's Avatar
SGB4570
Nice, I'll have to go look at that. Did you disconnect the battery first?
Old 08-20-24 | 05:08 PM
Sc888's Avatar
Sc888
Yes, I did disconnected the battery and waited 10 mins before I mess with the wires.
The following 2 users liked this post by Sc888:
doobs (08-20-24), SGB4570 (08-20-24)
Old 08-27-24 | 08:27 AM
SGB4570's Avatar
SGB4570
Originally Posted by Sc888
Just an update for the b0106 airbag code. I finally got a chance to troubleshoot the code today. I ended up removing the glove box to get access to the airbag wires. I couldn't see the connections at the ends of the airbag but was able to stick my hand in to feel it. I just pressed the connector in to make sure that it was secure on the right side of the airbag. When I started the engine the airbag code went away. Looks like it was a loose connection after all just like the picture posted by Nevada. Hopefully this helps someone.
Ok, went to do this today, how did you remove the glovebox?? I have a full set of shop manuals and nowhere in them can I find any reference to the glovebox at all. I got it way open and all I could find was 2 small screws in the upper outside corners, I removed those and it was still tight in there. Help.
Old 08-27-24 | 08:32 AM
Sc888's Avatar
Sc888
I followed the instructions on this video, was not too hard:
SGB4570 (08-27-24)
Old 08-27-24 | 08:47 AM
SGB4570's Avatar
SGB4570
https://www.youtube.com/watch?v=khzBGmT0nMY
Does that bottom panel need to come out first?
Old 08-27-24 | 08:49 AM
Sc888's Avatar
Sc888
Yes, that does come out first.
SGB4570 (08-27-24)
vbabu2
04-08-24 06:23 AM
coupdabill
09-05-12 12:58 PM
FrankWhite
05-30-06 03:20 PM
