SC430 Color Question?
I was wondering if someone can give me the name of the Pearl White Color that comes on the SC430's and also the Paint Code to that color? thanx in advance, peace!
The only white at lexus.com is white gold crystal. Select color at this page:
http://www.lexus.com/models/sc/exterior.html#
color code here: http://www.paintscratch.com/cgi-bin/makepaint2.cgi
Forget about using that Lexus White Touch-up Paint (#065 and ##065-0B) you get from Lexus parts. It is NOT, repeat, NOT going to match the color of your white Lexus....no way...UNLESS it was taken from the same batch that was used to paint your car at the factory. ...and thats not going to happen... .....What you need to do is get your Lexus Paint and Body Department to mix you up a batch....Thats what I did, and the match was perfect.....If you use the touch-up product, its going to go on flat white...not the pearl "gold" metalic thats on your car....and will look worse than the nick/scratch....Trust me....I went thru this......Good luck
Ef8people
03-05-14 11:55 AM
