Maintenance Costs
I just had my SC430 in for its 15k service. There is just one Lexus dealer servicing the greater Baltimore area, so I am curious what others are being charged for their services.
My 15k service totaled $536 and appears to have included changing the transmission and differential fluids, as well as a new air/pollen filter. This seems a little steep to me, but how does this compare to others?
My 10k service totaled $122 and appears to have been nothing more than an oil change. Again, this appears a bit excessive to me.
I just did that same 'Level B' service on my SC430 at 1 year/10k miles. $376 total, plus and extra $60 or so for balancing all four tires. They also replaced the front rotors and pads under warranty due to a vibration under braking.
I'll be going to local shops for my 'Level A'/5000 mile services, I'm not payin' $100 for a friggin' oil change, even if the cookies ARE good.
You can get oil changes, spark plugs, coolant, etc....at a Toyota shop for about 50-60% of what Lexus service shops charge , an still get the SAME Toyota / Lexus filters , fluids, and materials.
You still need a Lexus shop, though, for warranty work...a Toyota shop can't do that...... (yet).
knowing how outrageous the prices for the service really are, I bought the maintenance plan for my 04 SC430 for like $1100/4 years. Since I bought the plan, the dealer also gave me a certificate for free tire replacements for the maintenance period. So I have Maintenance and Tires for the next 4 years for $1100. Not a bad deal I dont think...
I'd recommend studying the owner's manual and/or Lexus maintenance recommendations here at the Club Lexus web site and then seeing if the Balt. Lexus dealer is willing to just do that maintenance (or insists on adding their fluff).
My closest dealer in the Wash DC-area was unwilling to do just the Lexus-recommended service (and each service advisor I talked with parroted a stock line about special driving conditions in the DC area). The next closest dealer was responsive and willing to do only the Lexus-recommended service procedures and was thus much less expensive (Pohanka Lexus).
I changed the air conditioner filter myself.
Thanks for all of the responses. I just got off the phone with my service advisor. He said that everything is part of Lexus' recommended 15k service:
Labor - $270
Parts:
- gasket - 1.08
- wiper blades - 20.17
- ATF, 4 quarts - 35.28
- gear oil, 4 quarts - 17.08
- motor oil, 6 quarts - 10.08
- air refiner element - 34.50
- air/pollen filter - 45.00
- oil filter - 6.35
Ok, the wiper blades and the air/pollen filter are extra. Does Lexus recommend transmission and differential fluid changes every $15k miles? I don't see that in the maintenance manual.
Labor - $270
Parts:
- gasket - 1.08
- oil filter - 6.35
you can get some of those items yourself and have them install it or do it yourself, like the Air Pollen Filter. It's $23 on irontoad.com but the dealership usually charges around $50.
I save on shipping by buying a couple of them as well as a couple of air filters. They should lower the price of the labor as well since you don't need them to install them. Search the boards and do what you can on your own.
Good luck!!
Good luck!!
Absolutely REDICULOUS. Last summer I had my 60K mile service done by Bill Spinney's automotive (deals only with high end foreign cars) The total came to about 600... this was for EVERYTHING including the timing belt, fuel filter, ignition coils, all fluids, torque all suspension and frame and essentially everything else.
