Power near dash?
Power near dash?
My installer is putting the EDFC in at the moment, anyone have suggestions on where they can get power for the controller under the dash?
Dozer
If you pull back the rubber at the door jam and lift off the door sill with the "Lexus" illuminated strip you can get the power from the seats. In the harness going to the driver's seat there are the wires for the heater. If I remember they are black/yellow and grey/yellow and are the bigger size. They belong to the circuit "22" I believe and you can check by popping out the fuse in the box by the passengers feet. Make sure to turn off the seat heater switch when testing for the current with your meter.I tapped into these wires and fished the wire back up to the dash when I installed my Passport. Good luck.
craigsager
06-12-14 05:07 PM
