C/d Jam In Mark Levison
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
HAS ANYONE EVER SEEN AN ERROR 3 COME ON THE AUDIO SCREEN. I THINK I JAMMED A C/D IN AND IT WILL NOT EJECT AND IT WILL NOT ACCEPT THE LOAD PROCESS. FEELING STUPID AND COULD USE SOME HELP, OTHERWISE ITS OFF FOR SERVICE AT LEXUS. THANKS DOC S
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
First of all, STOP YELLING AT US!
Second, I don't think I have seen "Error 3," but I've had a few jammed CDs from time to time. This can happen especially if you are using home made CDs with a paper stick-on label. Don't use those. The heat inside the unit melts the glue and the label curls up and jams on eject. If you record your own to use in the car, just write on the CD with a black felt-tip marker.
Sometimes a normal eject jam can be cleared by using a credit card or the edge of another CD to guide the jammed out CD as it tries to come out of the little slot when the door opens.
Be sure to push load and eject for the jammed CD location to be sure you are getting a complete recycle.
If that does not work, I think you are screwed.
Everything else probably requires special tools.
. . . . at least.
You did grease them up before inserting them, didn't you?
. . . . at least.
Sorry , I did not know i was yelling.. Thanks to those of you that offered suggestions. Still no luck, it goes to servce next week.I can only imagine the service time to get in there and get it out then put it back together.
