More Badge - Debadge
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Very nice look debadged! (I fixed your first pic link for you too)
I think that looks great. Definitely a cleaner look. Has anyone debadged an older SC430 and how did the paint under the badge look compared to what had been exposed for a year or two. I've got a red SC that is a year old, and am worried that the paint under the badge might look a little fresher than the rest of the paint. David
I debadged mine the first day. The HUGE front emblem was gone the same day too (can't make the stupid image appear here; see it in my gallery).
FWCruiser, I wouldn't worry about the paint being faded unless you had the sun shining on the back of the car for the whole year. Even then, with such a new car, a polish job would make it disappear. If everything fails, you can always put it back; try one first.
Originally posted by ohsuzyQ
What did it take to remove the badges?
I used fishing line and a hair dryer. I kept heat on each letter while pulling the fishing line through. None of the letters broke it came off in 1 piece. It didn’t take long at all maybe 2 or 3 minutes to get the Lexus off. After I removed the letters I kept the heat on the remaining glue and peeled most of it off with my fingers. That got a bit hot, but it was worth it as I didn’t have that much glue to clean up. I used an orange based house hold cleaner to get the remaining glue off, worked great.
BT
BT
Here's the front. I was going to grind off the mounting tab but I hit it with black magic marker . I guess it looks OK if you don't focus on it. I'm thinking about trying to fabricate a mesh grill along the lines of the white TT . Anybody wanna help?
![](http://face-dancer.com/images/Lexus/front.jpg)
I finally got around to debadging my '02 SC a few months ago. There is only the SLIGHTEST residual outline of the two rear decals (from the adhesive, I assume) but absolutely no paint fading whatsoever. These outlines are visible ONLY when the sun hits the car at EXACTLY the right angle, and my expectation is that they will disappear completely after a couple more Zaino treatments.
Originally posted by bt430
Here's the front. I was going to grind off the mounting tab but I hit it with black magic marker . I'm thinking about trying to fabricate a mesh grill along the lines of the white TT . Anybody wanna help?
Hey, what mesh grille (white TT) are you talking about ? A mesh grille sounds interesting. Post your ideas and/or progress.
Good day.
Here's an idea of the grill. Anderson Audio in Atlanta did a ton of work to this car. I don't think I'd put the "L" back on and maybe use a wider mesh . I had a 1/2" mesh on my M5 and it looked pretty sweet, but it's really hard to work with. So maybe a smaller mesh is the way to go. I'm not sure what's on a Jag but it looks close to what Anderson used.
![](http://face-dancer.com/images/Lexus/grill.jpg)
