bugs on car
I'm trying to get rid of the bugs that smashed into my front bumper. I have tried the bug-off thing and some it goes away, albeit not all. I'm afraid of scratching the car if I take scouring pad to it. Has anyone successfully used some method (chemical or otherwise) to remove these dead pesky insects?
Thanks.
Thanks.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
If this doen't work nothing will: Using an all purpose cleaner allow the product to soak, then use a plastic net sponge to remove the fatalities. I use meguiars car wash soap, and then detailing clay, and then wash again to remove the residue. Followed up with a sealant ( All in One, Meguiars NXT, etc)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Turtle Wax makes a "bug and tar" remover that I've been using for 10 years with nothing but successful results. It is also good for removing scuff marks on the doorsills. However, once you get it cleaned-up you may want to consider a clear bra to protect your car in the future. I have XPEL on my entire front-end, headlights, fog lamps, and side mirrors - and it works! No chips or scratches, and the bugs wipe off with not much effort. BTW, the stomachs of some bugs contain a corrosive agent; so getting them off quickly will help to save the finish on the paint. Good luck!
Before Xpel and Zaino:
Bug count = 20 out of 20
After Xpel and Zaino:
Bug count = 2-5 out of 20
Those pesky critters now just bounce off that Xpel w/ the slick Zaino.
As far as those nasty looking blood splats and gunk from the bigger bugs, there's none.
teeman3
'03 Millenium Silver
Xpel + 20 coats of Zaino
teeman3
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Thanks guys, I try it out. I should've put the Xpel on at the start, but thought it would ruin the paint over time as, i would assume, the part that is covered will experience less oxidation/sun bleaching over time. Yeah that front end is so flat, all the bugs get mooshed up into it. Any body also have problems with the passenger seat having a rattle of some sort? It sounds like the side or back plastic loose or something. It's driving me nuts!!!! I tried to push on the parts and they seem to be pretty sturdy. Any ideas?
BT
I have no expel, and removing bugs is never a problem with 'Plexus' . Use it for both my bikes and cars; great stuff.
What was rattling on my passenger's seat was the seatbelt buckle. Tuck it in (or buckle it) and see if the rattle goes away.
Good luck
Good luck
