Musty odor
Old 11-08-04, 05:40 PM
jlcartersr
jlcartersr's Avatar
Default Musty odor
I puchased a 2002 last year so I'm not sure if my SC430 was used on or near a farm but when I turn on the AC, I initialy get this musty farm odor. It gradually get less potent but it really annoying. I took it to the dealer to check it and it cleared up for about a month. It's back again. I've cleaned & Febreeze the AC air filter first. All indications point to the AC condenser. It gets worst the longer I leave the AC off.
Is there help for this?
Old 11-08-04, 06:09 PM
PROY
PROY's Avatar
Have the AC system flushed. Draining and refilling might help.
Old 11-09-04, 09:47 AM
DropTop430
DropTop430's Avatar
Have the dealer spray a product called "frigi fresh" into the system, its cheap and kills all the bacteria and mould. That is more than likely causing your problem.
Hope that helps
Old 11-09-04, 04:56 PM
tfischer
tfischer's Avatar
Obviously it's in the air handling part of the system rather than in the compressor. Something is in the ducts or in the filter.
I would not think "flushing" the system will do anything to help your problem. You need to have all of the duct work cleaned out to get rid of the smell.
You have sick car syndrome.
Old 11-11-04, 02:07 PM
antigeek
antigeek's Avatar
I've got the same problem. It started last summer.
Smells like a bread factory when the AC starts, then fades (until the next time).
I've had the dealer replace the air filter (which they said was the problem), and later put in Frigi-fresh. Each time resulted in a minor (and temporary) improvement.
I have heard that the system is tucked into the car so it's hard to physically clean out.
If anyone comes up with a solution, please post it!
Old 11-14-04, 10:07 PM
JCtx
JCtx's Avatar
I don't keep my cars too long, and that's probably why I never had this problem, rather than the supposed solution I was given once. Here it is anyway: Shut the compressor off a minute before you turn your car off, or just enough so the air is not that cold before shutting off your engine.
Supposedly, the ice cold condenser causes the musty odor over time. Sounded convincing enough to me, and doesn't hurt to do it.
Old 12-15-04, 01:23 PM
vvking
vvking's Avatar
I had the same problem - 02 SC delivered in April 01. Dealer replaced the cabin air filter (which is up behind the glove box) and the smell seems to have gone away (at least for the past month).
Old 12-15-04, 08:01 PM
Umbo
Umbo's Avatar
I've had this problem with almost every car I've owned. It is due to moisture condensing on the cold a/c coil from humid air. Mold grows on the moisture and farm stink is the result. Running the fan on high with the a/c off for several minutes before turning the car off helps.
ruetzal
IS - 1st Gen (2001-2005)
08-12-10 04:23 PM
Coconut
12-08-08 01:28 PM
GSsnarl
07-30-05 02:41 AM
Prost
Automotive Care & Detailing
05-07-03 01:04 AM
George Hsieh
01-06-03 03:26 PM
Quick Reply: Musty odor
