Slight Vibration in Steering Wheel
Just took my 2002 SC430 out of winter storage and the steering wheel seems to vibrate a little at speeds over 50. The problem is that since I haven't driven the car for 5 months I can't remember if this is the way it has always been. Also, just had the car serviced and the tech filled the tires to 37 psi, I usally keep them between 33 and 34. Any recommendations.
Thanks for the help.
It's possible that your tires have "flat-bottomed" after 5 months of winter storage, thus the feeling of imbalance when driving on highway. Not exactly sure of the remedy for this though.
yeah, did you jack up the car when it's there for 5 months? if no, probably the bottom of the tire is flat. it's actually very bad on teh tires, coz' it's 3800lb sitting on top of them for 5 months. it can damage the tire. you should haev jacked up the car and put it on stands
anyway, drive around, and maybe get the tires for balance and see if that's ok
During the summer I use 38psi in my runflats. This is as determined by ambient air temperature and varies seasonally by charts in a Lexus TSIB..
The Lexus TSIB is PG005-02 Titled:Adjustment of Tire Inflation Pressure dated:April 04, 2002..
I think the TSIB is in the CL library. If not ask your SM about it.
Ron
Ron
Thanks for all of the feedback. It sounds like you may have it nailed. Have been driving the car for the last number of days and it seems to be getting a little better. Next year I will store on jacks or pads. Thanks.
if you put the car on stands, "technically" the best thing is to take off the wheels and put them flat (stack them up together). but that's up to you i guess
good luck!
Vibrations like that you describe also develop when the wheels need to be balanced. Over the years, I have had vibrations develop at 50+ mph on a few occasions, and the problem was corrected when I brought the car in for balancing.
Flat spots of 5 months go away by themselves, especially if tires were properly inflated, but might take a little while. Just be patient.
I don't think it's anything else, since you mentioned it started doing it right after storage (storage doesn't mess up your alignment or wheel balance).
Have a great weekend everybody.
JC
JC
