Does bluetooth come on sc430
have you looked at other YouTube videos? They may look a little different due to different Lexus/Toyota model, but may function the same...I know I could get a nav unit from a Prius and it will work in our car.
are the buttons the same...I mean the Bluetooth connection process should be fairly simple.
i did see where there was a list of phones your Bluetooth should work with...
anyway, just trying to help.
But did you try the steps?
The BT module on 2005+ SC is probably located in the screen unit which is connected to the Nav in the trunk. In order for factory Bluetooth to work both BT module and microphone have to be there. If 2002-2004 SC don't have either of those its unlikely just replacing the NAV unit is going to do the trick. Apparently, the NAV is smart enough to know that both BT module in the screen unit and mic in the mirror assembly are missing, thus it doesn't show you BT options. Fortunately, you got your Grom working so most BT features are there.
The headunit (the Nav Screen) is where the menu software resides and I think BT module too. If you look at the 2005+ SC Nav user manual it contains two portions, one is the NAV functions and the other is the phone functions. Your trunk NAV only is needed for the Nav features; it has nothing to do the phone portion. So if 2002 SC the head unit does not contain any phone features it naturally would not have BT module inside. Hope that explains.
Hope this helps-from my manual for an '07. "Navigation System Owner's Manual". Hope this helps. I feel your pain on this. Attached shows pages 134-149, may be more info than you wanted. It took me a while. Mike
Enigma869
06-27-23 05:29 AM
tonydt1g3r
07-26-06 05:55 PM
