Wheel Photos please
Wheel Photos please
Dose any one have any photos of AT Italia Inox Chrome 18x8
or Enkei LMI / 5S Chrome 18x8 wheels on a SC430?
I would really like to see these on the car before I buy.
Thanks in advance
Thanks in advance
You can go to tirerack.com to check it out.
I believe they show you how these look like on your car.
I found one pic, but it is a GS.
19"s will look more right and wider is better.
In my opinion, you should probably save up a little more money and get a set of nicer rims for your sc later on.
I am not saying these are bad. Just be patient, don't need to hurry ....
you can get run flats in more than one size. (also- anyone know anything about streching run flats? ) with the SC430- if your not going to go wider / bigger - then just get the TRD center caps and call it quits. But the SC430 begs for a 19 or 20 with a streched 265 on an 11" wide wheel in the rear!!!!!!!!! and a 235 streched on a 9.5 or 10 up front
Originally Posted by Joe Peters
I don't /can't buy new tires have stock size GoodYear non runflats.
How wide can the wheel be with these tires?
What size is on the GS photo/
More photos please.
More photos please.
If you want to keep your 18" tires and tire sensors, 18" TRD will be a better choice.
Quoted from the ad:
"The TRD wheel is specifically designed for the SC430. The wheel is hub-centric and is counter-weighted to offset the air pressure sensor used in each OE wheel."
I want to be able to rotate tires so cant stager.
Don't want any bolt heads to clean.
RunCraps? Never again!
Last flat on my Vette cost almost 400 bucks.
I just want a simple 5 spoke chrome wheel
with out spending a ton of money on new tires
when I have almost new tires now.
Leaning toward Enkei : LMI / 5S Wheels
if any one has pics of this wheel on a SC430
Please Email it to me.
Thanks
Thanks
JerseySC
06-09-03 07:05 PM
