quarter windows
That is a great idea.
I wish you would have mentioned that before i finished this one. Oh well maybe next time.
Window sense means the LuxLink knows what position the windows are in. Rather they are going up or down. This way when we close the top the windows will raise all the way up before the top shuts down and when we open the top the windows will remain open.
I currently have LuxLink installed in my SC and would be interested in an upgrade (even a prototype would be OK!).
Does the new system use the same wiring harness as the old one or do we need to remove the old harness and replace it with the new one?
Thanks,
Baldy
Thanks,
Baldy
Maybe if you would have mentioned it before I finished this unit I would have concidered it.
The new system is completely different and the old one will have to be removed.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Well I dont see why it couldnt be an add on part. If you hook up a relay to the sensor and wire it up to where you would set the top to close, IE like the command to close the top from the remote then I think it wouldnt be too hard. But I am not sure how your current architecture looks. I think if you made it an add on to luxlink people would buy it for sure.
UNOHOO
IS - 1st Gen (2001-2005)
08-16-09 10:15 PM
