Whats the difference in size from stocks to 20's
I was wondering what is the height difference from the stocks to 20's height wise including the tire. I want to get a picture in my head of how much the gap is filled and how much lower the car will need to be dropped.
http://www.miata.net/garage/tirecalcold.html
The One
why wouldnt you use 35's all around
Remember this number is an aspect ratio to determine the sidewall height. It is a percentage of the tire width (245, 285 in this case). As you can see, 35% of 245 < 35% of 285.
Originally Posted by Neo
Well, if you are going with a staggered setup, 35s all around will make the front wheel diameter smaller than the rear. With cars not setup for different wheel diameters, it is optimal to try to retain the same size (like OEM).
The One
rominl alluded to a staggered setup and my statement started with "if you are going with a staggered setup".
The OEM setup is not staggered. The OEM rims are 18x8 all around. If you get the same rims all around (non-staggered - for example 20x8.5), then you would only be using 245/35 tires all around.
If you do staggered (for example 20x8.5 front and 20x10 rear), then you'd have to use different series tires with the sizes above as an example.
Ok I think I get it now, I always thought staggered set up was just different width tires up front and in the back, IE 245's up front and 285's in the rear. I didnt think the height of the tires had to deal with the staggered setup IE 35's up front and 30's in the rear I thought it could be the same size. Thanks for the clarification
The One
For our cars, you WANT to keep the front and rear diameters the same. This is why you have to play with the numbers to get the specs right.
exclusive matchup
Well, you are right that it has to do with different widths the way you described it. The way tire specs are setup, though, is that the sidewall height (and ultimately the overall height/diameter) is based on the ratio of the first and second number.
AHH I see the light. So 35 for a 245 width tire isnt the same height as a 35 for a 285 width tire. And since that is the case its harder to maintain the same diameter for front and back. Or maintain the raition of width and height of a tire. What is the ratio supose to be?
So Henry, if we are using 19x9f and 19x10r on an sc. We go with 245/35(85.75mm) in the front, but why do we go with 275/30(82.50) in the rear. Thats off by 3.25 mm. Shouldn't we go with 285/30(85.50mm) or is that to wide for the car? I know it is only 3mm difference in height, but to have the 3mm shorter in the back is funny. If it was 3mm shorter in the front then atleast the car would sit right
