SC430 wheel fitment
Old 02-19-12, 08:30 PM
  #211
braheem
braheem's Avatar
FYI Everyone,
I just installed some rims with 10.5 Wide +39 with 295/30-20 tires in the rear they're flush with the fender when looking under the car I still have at least another inch of space for tire width.
My my calcs,...
1. If I upgrade to an 11 inch rim that would need to be offset by 6mm so It would need a 46 offset to stay flush.
2. If I have an inch of space on the inside I can upgrade my tires by 20mm.
3. If I widen tires by 20mm to 315/25-20 I would have to offset the 20mm by half to stay flush so final offset would be +56.
Have I missed anything in my calcs?
Old 02-20-12, 08:17 AM
  #212
cyberlexus
cyberlexus's Avatar
I think +52 on 11 is risky, so you probably want to test fit before ordering the wheels. There is a member here with 20x11 +33 with 295 tires.
Old 02-20-12, 08:47 PM
  #213
braheem
braheem's Avatar
A 295 on an 11" rim is a stretched fit at +33 he's only 9mm further in then my rims, I can easily add an inch of rim/tire on the inside without any rubbing 9mm still has 16mm of unused space.
Has no one ever tried a 325/25-20?
Old 02-22-12, 11:41 AM
  #214
Brian@Vossen
Former Sponsor
Brian@Vossen's Avatar
Someone needs to throw some Concave goodness on the SC 430!
Old 02-22-12, 12:51 PM
  #215
braheem
braheem's Avatar
Hook me up with a 10.5 rear 55ish offset and I'll do the photoshoot and provide the 325 Tires on an SC430.
Old 03-24-12, 07:09 PM
  #216
Z3NK1
Z3NK1's Avatar
This could get nasty, 20x10.5+9
Attached Thumbnails SC430 wheel fitment-20120324_152534_450x600.jpg   SC430 wheel fitment-20120324_152552_800x600.jpg   SC430 wheel fitment-20120324_152601_450x600.jpg   SC430 wheel fitment-20120324_153515_450x600.jpg
rakish1 (04-11-21)
Old 04-03-12, 04:32 PM
  #217
barncat
barncat's Avatar
I had a wheel crack which had the run-flats. Is this a problem with them? I've only had the car 1 week. 03 sc430 ( Added note; I had two cracked rims with run-flats on! Opposing sides.}
Old 04-04-12, 03:33 AM
  #218
I-FORCE
I-FORCE's Avatar
Originally Posted by I-FORCE
Help needed guys..
I have been looking at a set of CE28N Volk Racing wheels for my 2010 SC.. The spec's offered are:-
Front Wheels:- 19x9.5 - +12, +22, +25, +36, +45
Rear Wheels:- 19x10.5 - +12, +22 +36
What would be the closest setting to flush i can reach without rubbing? I intend on lowering the car with Coilovers soon.. Due to the nature of our roads, i wont be lowering too much, maybe and inch give or take.
Secondly, What tires should i go with, 245/35-19 - 275/30-19 or 255/35-19 - 285/30-19?
Thanks,
Moe
Bump.. What do the proffesionals recommend on this, i really want to order a set soon.
In addition to the CE28Ns.. I have also been looking at the CCW Classics
https://www.clublexus.com/forums/sc-...-an-sc430.html
Thanks,
Moe
Old 04-04-12, 07:38 PM
  #219
braheem
braheem's Avatar
36 front
36 rear
No shaving required
Old 04-07-12, 02:00 AM
  #220
I-FORCE
I-FORCE's Avatar
Originally Posted by braheem
36 front
36 rear
No shaving required
Nice is this going to be aggressive enough or is it still going to tuck a few inches into the fender.. i really like the design of the 2010 SC wheels but they're damn offset is a disaster and i hate spacers.. i wanna get wheels asap to get rid of the spacers
Thanks
Moe
Old 04-07-12, 07:03 AM
  #221
braheem
braheem's Avatar
Ya Hamada, If you're doing 245 or less front go with +25 front, the back must be 295 to 315 to be flush. Quit stressing i did 2 months of research for my setup it will be a clean factory looking M3 looking setup, the way it should have been from the beginning.
Ibrahim
Old 04-18-12, 11:54 AM
  #222
nktuner
nktuner's Avatar
Thanks
Moe
Hi All, This is my Volk GTC 9.5 in Front OD +36 with factory height looks like.
I try on yesterday.
Old 04-18-12, 12:00 PM
  #223
nktuner
nktuner's Avatar
This is the back w/GTC 19x9.5 OD +26 Wheels only . Just Try On ! You see its flash on the fender .
Old 04-21-12, 02:30 PM
  #224
nktuner
nktuner's Avatar
Hi All,
finally tires on without runflat tires, total different !
Old 04-23-12, 01:52 PM
  #225
nktuner
nktuner's Avatar
Tires & rims on
Quick Reply: SC430 wheel fitment
