SC430 wheel fitment
Old 07-21-22, 02:52 PM
  #496
MYDRPTP1
2nd gear
MYDRPTP1's Avatar
what set up did you end up going with?
Old 10-28-22, 01:14 PM
  #497
doobs
doobs's Avatar
Can someone please provide a positive id on these wheels?
Thank you!
nzxyxy (11-24-23)
Old 10-29-22, 08:19 PM
  #498
SC300Es
SC300Es's Avatar
think they are called Lexus G Spider wheels.
https://parts.lexus.com/p/Lexus__/18...845753811.html
Old 10-30-22, 03:16 PM
  #499
doobs
doobs's Avatar
Thank you!
Old 12-07-22, 03:48 PM
  #500
AVSRacing
AVSRacing's Avatar
Any idea how these will fit? Width isn't as wide as what some of you guys run but offset is very low. 20x9 +5 and 20x10 +6, thanks!
Old 07-10-23, 05:20 PM
  #501
jerdjerzey
1st Gear
jerdjerzey's Avatar
Default Rubbing +15 offset
Hello. I need some help. My front tire rubs when driving when the car dips on uneven roads. The tires is sticking out a little too much. The wheels are 20x8. Offset +15. Tires are 245/35/20. What is the best option to fix this issue? Thanks
Old 08-20-23, 07:10 PM
  #502
AVSRacing
AVSRacing's Avatar
Get some 225 up front
Old 11-30-23, 04:05 PM
  #503
Dave47
1st Gear
Dave47's Avatar
Default 2008 sc430
So I’m changing out wheels with GS350. Bore and thread are the same as the SC430. Would like any comments or opinions on ride quality or fitment before I pull the plug.
Wheels are
Front 19x8 41mm offset
Rear 19x9 60mm offset
Tires I’m considering:
Front 235/40 No Offset
Rear 275/30 or 265/35 and may add a 30mm offset.
Any Thoughts
Old 03-20-24, 10:30 AM
  #504
AVSRacing
AVSRacing's Avatar
You might need spacers on the rear the offset is stupid high and will look sunk into the wheel wells. Need to test fit first. I doubt you need tires that wide on a 9 wheel.
Old 07-20-24, 09:10 AM
  #505
arkijak
arkijak's Avatar
Default Tire stretch
SC 430: Looking at new wheels. Can the original 245/40R18 tires safely stretch to 9.5 inches? I want to mount them on 5x114.3 / +30 73.1 wheels. Car is lowered 1.5”. Also will the tires rub the fenders? Thanks
Quick Reply: SC430 wheel fitment
