Hello. I need some help. My front tire rubs when driving when the car dips on uneven roads. The tires is sticking out a little too much. The wheels are 20x8. Offset +15. Tires are 245/35/20. What is the best option to fix this issue? Thanks
So I’m changing out wheels with GS350. Bore and thread are the same as the SC430. Would like any comments or opinions on ride quality or fitment before I pull the plug.
Wheels are
Front 19x8 41mm offset
Rear 19x9 60mm offset
Tires I’m considering:
Front 235/40 No Offset
Rear 275/30 or 265/35 and may add a 30mm offset.
Any Thoughts
You might need spacers on the rear the offset is stupid high and will look sunk into the wheel wells. Need to test fit first. I doubt you need tires that wide on a 9 wheel.
