SC430 wheel fitment
#106
There is red spray paint offered on eBay to change the lens color... I have no experience with it. There are usually several sellers and they may offer different size spray cans and prices.
PS using red lens in the front may not be legal, think emergency use only and a potential ticket... check your local law to be sure.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Buster06 (06-29-20)
#107
I recently bought TSW Londrina chrome (staggared) and here's a look...
My setup;
Front 20x8.5 ET20
Rear 20x10 ET25
My setup;
Front 20x8.5 ET20
Rear 20x10 ET25
Ok, so I'm way new at this and was wondering if.. these will fit. According to the chart that Rominl posted it will, but I just wanted to know if it will sit close to "flush"? (I'm assuming that flush means everything lines up)
20 X 8.5 +20
20 X 10 + 25
Thanks for bearing with me lol.
20 X 8.5 +20
20 X 10 + 25
#108
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
....stock suspension; no rubbing. Firm, yet very smooth ride.. just what you would expect from a LEXUS> I had considered lowering it, but it looks pretty tight as is... I may consider a subtle body kit (at least the front spoiler) though.
#109
I could use some help. I am new to the after market rim and tire game.
I have found a used set of 20" Stern ST-2 Touring Sport Chrome wheels; 20 x 8.5" (front) and 20 x 9.5" (rear) with a 5 x 4.5... 5x114.3 bolt pattern. Offset is 35mm front and rear. The tires are Falken FK452, 245/35/20 (front) and 275/30/20 (rear) and are like new.
I have a stock suspension.
Would these rims and tires work on my 04 SC430? Would the 35mm offset be OK? Would they line up flush? Are the tires to large for the fenders? Would they rub?
Thanks for your help.
#110
https://www.clublexus.com/forums/sc-...nd-stance.html
There's a link to my setup, I've listed my specs on the thread as well. Hopefully those comparisons should help you.
Good luck and when you get the new wheels, ENJOY!
#111
RominL could you explain what "Within spec?" means for tire size. I bought some vossen 9 and 10.5 wheels for my sc 430 and I am trying to figure out which tire would be best. Thinking about Falken or Pirelli but not sure which tire to pick?
#112
Need help.. Trying to see how aggressive I can go.
How much work am I looking at to make this setup fit??
20x9 -19 hi disk (101mm of lip = 3.98")
Falken 452 235/30/20
20x10 -16 s-lo disk (114mm of lip = 4.49")
Falken 452 245/30/20
#113
Fender pulling + stretched tires won't be enough to make them fit.
Those specs are like adding 44mm spacers in the front and 41mm spacers in the rear to my current setup.
If you can make them fit, your car would look really awesome.
I've found a sc that has similar setup, but yours is still more aggressive than this one by 7mm in the front and 4mm in the rear.
Leon Hardiritt RASEN
F: 20 x 10 +0, Yokohama Advan 245/30/20
R: 20 x 11 +0, Yokohama Advan 245/30/20
![Name: p1-35.jpg
Size: 53.1 KB](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/453620d1501791993-sc430-wheel-fitment-p1-35.jpg)
#114
man, you need some body work done on the fenders and probably even on the bumpers.
![](http://i55.photobucket.com/albums/g159/keikomd/SC430/p1-35.jpg)
Thats ALOT of work.. Im ok with the fenders.. but the bumpers??
Check your PM..
#115
http://www.lgwnorcal.com/articles/wheelfitment.html
i finished up the guide and posted it up, hopefully it can help members. it will be integrated with my old guideline soon
Thanks
Fred
#116
BNR34
Verry Sweet. Nice balance between the tire profile & the offset. The tires look like they max out the OEM wheels. What are the tire specs & the spacer configuration? Which brands did you go with? How much do you plan to lower--that's really going to be awesome!
#117
The pics you saw of my car was with stock tire size 245/40/18, spacers sizes are 20mm in the front and 30mm in the rear, the spacers are project Kics.
I am still having a tough time deciding which springs I am going with, it will be either H&R or Tein S-tech, their lowering specs are:
H&R F&R -1.2"
S-Tech F -1.3" R -1.6"
#118
i'm looking at new wheels to replace my deceased works. what do you guys think of this fitment? i'm a little worried about rubbing in the front. and i don't want to do any fender mods.
20x9 +14 (245/35/20) front
20x9.5 +17 (275/30/20) rear
