** Group Buy ** Lexus 2002-2005 SC430 Tail light Upgrade **
The part number is in the other post I put up a while ago as the bulb is difficult to find from an auto parts store.
Found the link. See the pic with the bulb. It appears to be a 4764 part number.
https://www.clublexus.com/forums/sho...d.php?t=187823
Lee
Lee
Hi everyone,
I'am new here
This is a huge forum
I drive a 2005 sc430 here in Holland, and its a huge car
I also like the upgrade kit for the sc430 and have order it !!! ( I hope L-Tune have receive my mail )
Greetz Patrick
I'am new here
Greetz Patrick
Originally Posted by tonydt1g3r
Well if you wanted to donate me a set I'd try to figure out a solution
What is really required is a schematic of the actual waring module to do this correctly. That may be harder to find than hen's teeth as the books only show wiring to the modules. Although "load resistors" wiil work, that is not the best way to solve the issue.
Peal is correct., a piece of tape, which has been used to block my tire pressure sensor when the previous owner put the crappy Maya rims on my car, works just fine.
NICE430
There is a module which the lights plug into which would ,"probably" fix everything. I have not checked on the price yet. Hate to spend the bucks and get stuck with it if things did not work. Now if a certain vendor (hint hint ) is willing to allow a return if this does not fix the light issue, then I may be willing to try it out depending on the price.
Lee
Lee
Originally Posted by KevsSC
I just received my 06 tails by UPS just now. I wanna put them in already but I gotta get the turn signal bulb first
Just make sure you have the bulbs in hand... the two Lexus Dealers I went to had to "order" them. This is something they don't seem to keep in stock yet.
Last thing you would need is getting a ticket for a turn-signal light.
I would suggest Carson add these to the kit to avoid this, as although it sounds like a non problem, it can be one.
If Carlsbad Lexus told the truth, I will have two on the shelf at 9:00 am tomm.
By the way, Carlsbad Lexus could not rid my right door of the bass-buzz. Got a line from the service dept. that "all radios buzz at high bass". What a sack of bull... I asked where they mentioned that in the glossy brochure touting the Mark Levenson high-end radio... that shut him up, but it still buzzes at certain passages. A true embarresment even after the "kit" which I had to point out (T/B) they knew nothing about. It isn't full volume when it occurs, so this is a defect which is pissing me off.
Anyone had better luck at another local dealer in S. OC? At least they replaced the fog light bulb at Carlsbad, but no more service from them after that song and dance. The Service Writer seemed out-to-lunch when I had my service write-up, a real boob. Toke him 30 minutes to write up a simple service ticket, and I had to go over and over the same things.
I sent them (Carlsbad L.) a note explaining my dis-satisfaction, but no response, so the last thing they get from me is the purchase of two amber bulbs.
NICE430
Well,
I don't have the part # handy, but I CAN tell you that trying to get these bulbs is turning out to be a major pain in the you know what.
Carlsbad Lexus, after telling me they would be here at 9 this am, now tells me, after I drove there with hopes, is that they need to come fron Dallas. Isn't that what computers are supposed to verify??
Folks help me out here, does anyone in S. OC or N SD counties have a Lexus dealer they can trust? I am getting tired of the 'ol jerk-around, and would like to know where to go to get decent service and parts response, not just big smiles and nice coffee with service and a parts department of a KIA dealer. Jez!!
(Was a) NICE430
(Was a) NICE430
