Speedometer Wiring Diagram
Hi,
I need the wiring diagram on the back of the speedometer for a lexus SC430 2003.
I consulted the site lexus tech europe and it is impossible to consult the pages for models prior to the year 2005 ...
I need to know the correspondence of the pins to connect the speedometer "on the table". Sorry if the phrase "on the table" is not understood in English.
Basically I need to test the speedometer and I need to know the connections to make on the pins
Thanks
Thanks
car left like the USA.
And this is my french speedometer : http://zupimages.net/viewer.php?id=19/25/fe6e.jpg
There are no "bulbs". There are Light Emitting Diodes or LEDs.
I have attached a PDF wiring diagram for the LHD Combination Meter, sometimes called a Speedometer.
Il n'y a pas de "bulbes". Il existe des diodes électroluminescentes et des diodes électroluminescentes. J'ai joint un schéma de câblage PDF pour le multimètre LHD, parfois appelé compteur de vitesse.
Thank you very much VVTIBob.
I knew it was not the right translation but I did not know the right word in English...
to be clearer, I need to know what each pin of this connector is for the 2003 SC430 :
http://zupimages.net/viewer.php?id=19/25/hu4n.jpg
But I am not an electrician... Can you confirm that your schema gives the information that I request (for my speedometer specialist) ?
It's to repair my engine light broken
And still sorry for my english. Our level of English in France is really bad
In addition to VVTIBob diagram, you'll need these 2. Just print and give them to your technician.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/741x848/annotation_2019_06_18_143738_7536fc0071caf7fad7ea91eef15604313408b210.jpg)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/693x701/annotation_2019_06_18_143731_929d589cfce248027cfe76d579e1c4f58556832f.jpg)
The schematic has pin number, wire color and circuit path to the various LEDs on the board. The technician, if qualified, should easily read this diagram.
Le schéma comporte le numéro de broche, la couleur du fil et le chemin de circuit des différentes DEL de la carte. Le technicien, s'il est qualifié, devrait facilement lire ce schéma.
It seems to me C9 is for car with the compass display (Hawaii? model) I remember that I only need to plug in the C8.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/630x835/combo_meter_fb6a6eef052b0443dcc8312d812bfd5f111ffd1f.png)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/475x199/c9_2205ad8c2980f805084b964bcf18f9c3dadb2b05.png)
