excess heat from floor board and vents
Welcome aboard.
I noticed this in my SC as well as almost most of my other cars. If I leave the heat settings on high or close to it then I will still feel the heat as the heater valve is left open and some heat will enter the cabin even with the fans off. Once I lower the temp I no longer feel the heat with the fans/climate controls off.
It is not excessive but I can feel it. Not so much when the recirculate option is on. Turning it off and bringing in fresh air from the outside is similar to leaving the fan on so heat will certainly come out of the vents.
Past all of that there is always the option that the temp control valve is stuck or malfunctioning and staying on but then the a/c would not be as effective.
Thanks for the info Pearlpower. I am going to take it back to the dealer and have them check if the temp control valve is stuck or malfunctioning. At least i'll have something to use. Thanks again.
allenclan1
10-30-20 12:46 PM
drivenGS
10-25-15 03:51 PM
TeamAM
27
08-22-07 10:37 AM
