Last edit by: IB Advertising
Browse all: Exterior Guides
- Car Cover Reviews
Reviews and comparisons of top products
FAQ - SC430 Car Cover - Which one? (Merged threads)
#106
Has anyone taken a chance on this one on eBay?
http://www.ebay.com/itm/180715509272...S:1123&vxp=mtr
The image shown of the 5 layers looks just like those I've seen on other more expensive web sites. Of course, I know it's easy to copy pics/images -- so that's not sufficient evidence that this is a quality cover.
I did ask the seller how much the cover weighs -- about 7 pounds.
Thanks for your thoughts,
-gene
-gene
#107
So I put the cover on the car. Feels sort of fuzzy and has what look like pinholes/perforations on both the outside and inside layers. They don't go all the way through so I'm thinking they're part of the "breathing" mechanism of the fabric.
It goes on well enough and is pretty form fitting. However, there's a strap that is supposed to run under the car and buckle into a piece hanging from the driver's side. Trying to adjust that while laying on the cold pavement was a minor PITA but made worse when the strap broke at the buckle (one of those plastic slip adjust ones). Came off almost like it was cut. Looking closely, it seemed the fabric took some kind of permanent crease from the position it was in the buckle piece and weakened it so pulling on it to tighten it tore the strap.
Two snow storms later (one a couple/three inches the other 8 or so) and having cleaned off the car/cover with each storm, I needed to take the SC out today due to an exploding soda can in the Benz (it was sitting in the console when the temps went below 0) - frozen diet coke froth all over the car (I vacuumed it later - didn't want to let it get warm and melt the frozen soda so took the SC instead).
The cover's fabric split in two places on the left & right side of the hood. One split was along a seam (seemed to be a thermally welded seam) right alongside the seam. The other was about 6" away from the seam on the main hood panel of the cover. One was about 18 inches long and the other about 30". Repaired both with Gorilla Duct Tape. It's holding for now but I don't hold out hope for more than a season before this thing hits the trash. Taking it off once led to two splits - who knows how many I'll get if I use it more regularly.
BTW, I the fabric was not split when I started to take it off so it must have split as I was pulling it off and turning the side over to the middle as I bundled it up to go in the garage.
YMMV but even at the $70 it cost me, it's not something I'll buy again for next winter.
#110
I have one of these
https://www.classicadditions.com/car...ar-covers.html
Had it for about three winters now and it is brilliant. It keeps my car in perfect condition and never marks the paintwork. You can even put it on when the car is wet. It is very soft and streches to fit.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1112x834/grill_5_aug_2014_660f9edd9b3eb45ac0229c743d63642761971d43.jpg)
Cheers
Steve
#114
That is a beautiful color, WIL44.
texassc430: Outdoor — no garage, and I'll probably put it on at work, too. Anything to keep the San Antonio sun at bay.
Slingshot, I ordered a Seal Skin cover. Thanks for the recommendation! WIL44, I liked that one very much, but I had already placed my order.
#115
No problem gospursgo the one you have ordered is probably very similar.
In the UK they call my colour Montrose Blue, but you guys know it as Indigo Ink Pearl. A much sexier name lol.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1112x834/1_30d83ea7b5bc3f0bc2e8c01bfc1f30174ae2fcb5.jpg)
Cheers
Steve
TitanG545 (06-05-20)
#116
Hi all...just got an 04 SC430. Unfortunately, my garage has my GX and my RX and the SC has to live outside much of the time. I'm in Southern Arizona where it is pretty sunny and hot. spring and summer.
Any recommendations for a good car cover? pros and cons? There are some trees near the car so it isn't in exposed sun all day.
I'm just thinking that it should have some exterior protection from tne sun and I'm looking for recommendations for a good,not-goiing-to-break-the-bank, car cover.
Thanks in advance.
Alan
Thanks in advance.
Alan
#117
Costco used to have a good car cover. It protects car from sun and rain very well. I still have it but I'm not using it because my SC is in the garage. I've tried to look for the name and/or the manufacturer but there wasn't any. Don't know if you can find it on line.
#118
swap the RX out.. you got a GX thats infinitely better and rotate the SC in
problem solved.
#119
I have a covercraft weathershield cover that I would recommend. The cover is not cheap (I think about $250) but it is very high quality. The cover is custom fit and is easy on and off. Protects from rain and sun. I have had it for four months and very pleas d with its protection.
#120
I am often reluctant to leave my top down where anyone cafn see what is in the car and pick up any loose items or even open hood, trunk, etc. Does anyone know if there is a custom cover that would cover the car when top is down? If so, where might I find one?[/QUOTE]
