The Sound Of Success! Sub Upgrade Complete
Originally Posted by aspguru
can you post how much $ you have invested in this project?
Sub woofer $110
Amp + bass controller $200
Walmart Wire Kit $30
Low Line Converter $20
Some Thicker speaker wire $5
A better set of RCA's $10
I also bought some extra nuts and bolts and some rubber gaskets to seal the sub $5
is it that much better than stock?
you have it as a direct replacement where the stock sub was right?
any issues with tonal balance throughout the system or noise?
... i thought the mark levinson system was supposed to be audiophile grade...thats why i never messed with it..
Direct Replacement have to custom the stock bracket a little bit to make sure it fits without hitting the metal bar in the back
The ML sub is small and crappy
SSK0771- Just buy what I did and send me an email to tonydt1g3r@aol.com I'll tell you how to cut the bracket its real easy but you dont want to mess up.
2 questions
1.what wires did you connect the low line level conver to?
A)wires at sub
B) other wires (if other wires what wires and where)
2.where did you connect the wire for the remote turn on for the amp
thanks!
A)wires at sub
thanks!
XxLS400xX
05-01-03 06:25 PM
