Supra or BBK upgrade still ok with stocks?
Lee
Did you create a conversion bracket for your rear Brembo's. I can't find a rear Brembo for the SC430. If you did what sort of material did you use and which model Brembo did you use.
Thanks,
Ross
Thanks,
Ross
Actually I have to fabricate the front and rear brackets for the Brembos. Once I start the fitting process it will take about 2-3 weeks from beginning to end and I will post everything at that time. The front calipers are the same as those found on the Carrera GT and GT2, just not ceramic of course. Front rotors/hats are pretty much finalized at 355mmx32mm with aluminum hats. Rears rotors are LS430 rotors.
Yes , plus the rears will be much less expensive with LS430 rear rotors. Just needs the brackets for the calipers. There is an option that deletes the factory parkng brake assembly and will allow custom rotor/hats in the rear with another smaller parking brake caliper next to the larger caliper but the price really skyrockets with this setup so I am going the simpler route even if the factory rotor is not as sexy as aluminum hats or match the hats for the fronts.
TexasGS
09-13-06 05:55 PM
