Got a buncha stuff in :) want to share
Yesterday my rims came in after a month and half of waiting
I got some 3 pc Iforged Retro's 20x9 on 255/35/20 20x10.5 285/30/20 in Hi Polish Finish.
Had my TPS sensors mounted
Here is a sneak peak
I just put one rim on the rear because my friend wanted to see how it looks on the car, but I took it right off after the picture.
I didnt want to put on the rims without dropping the car first. So first things first I am going to drop my car tonight with the tein springs I've had for a while
I came home from picking these up and found my a box that says daizen at my front door
I didnt have time to open it or look through it. I assume it would be a good time to install these also since I am working on the suspension. Does anyone know if it includes instructions in the box? Which setting should i put it at? Any tips on install, I remember rominl had some problems with someone installing them wrong?
And I just got a call now from my friend at lexus and she said my parts for my tail light installs are in and the cost is $400 without the ecu
Did I save alot or what!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
very nice, you are right that don't put the rims on without lowering ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
about sways, there are instructions, inside. make sure you pay attention to end links
about taillights, not sure if you saved a lot. read the GB thread from a while back, the ecu alone is like 170 bucks, so subtract that and see
$520 for light kit without ECU if I remember correctly
Also which setting should I use on the sway bars rominl? Any reccomendations
Mike, I think I will get one sooner or later but right now I am spending way too much
hardest setting for both front and rear? are those the two holes at the end?
Also the parts department is retarded They gave me 1 set of 2006 tail lights and one set of 2002-2005 tail lights. What retards .
and they gave you ONE 06 and ONE 02-05 taillights? now that's something funny
Tony,
I'm about to get some 3-piece iForged wheels & saw this thread when I did a search...How's it working out w/the TPS stuff mounted? How did u mount them & did iForged provide all the stuff needed to mount? Thx!
