rolling fenders on an SC430?
#46
Originally Posted by rominl
you know josh, way back when i first got my gs400 i thought the same way too, it's just about springs/shocks compressing right? but for whatever resaon, it's different. by lowering the car more you do indeed create a bit more "space" i don't know why, maybe someone can explain
lowering does change the camber but no more so than hitting a bump in the road that would compress the suspension the same distance. when you lower the car all you are doing essentially is compressing the suspension, just like hitting a bump or putting 5 people in your car.
The only possible variable here would be deflection from bushings or any components that might flex when under any lateral forces present.
I hope I explained it properly.
Josh
#47
Originally Posted by aspguru
It doesnt matter what point on a fixed path you start, the end result is the same. It isnt possible that the suspension geometry changes because of the ride height. The upper and lower A arms control the path that the tire travels as they cycle through their range of motion. Unless those items are changing their length do to the ride height (obviously they dont do that) the tire will end up in the same position regardless of where it starts (ride height)
Josh
Josh
Originally Posted by bt430
I'm confused on the camber thing. Is the additional 2 degress of camber gained from lowering the car or can an alignment shop dial it in?
#48
you guys are using the same tires?
Hey Henry, I intuitively agree with this Josh, but you could be right too. It does seem that the only way to actually create more wheel clearance is to change some other suspension component/linkage, at least to me. I don't plan on lowering my car, at least not yet. But then again, I said that about my TL too.
#49
Originally Posted by tonydt1g3r
i was taking a closer look at your pictures and it doesnt look that out of spec. I think mine would look about the same if I was at stock height. can you take a picture of it from the read like behind the back bumper so I can see all the tread of the rear tire and compare that to my car to see how bad it is.
here's a pic...
#50
i am not sure if i like the idea of putting more negative camber on your wheel for no reason? you are going to introduce more camber wear and your car is not even lowered?
#52
umm..... really doesn't seem like you are clearing t all.......
you have 10.5 right? what tires you have there again, and what's the exact size?
i wonder if it's coz' you get tires that are meaty causing the rub
#54
#55
take off that black plastic lip that is rubbing and use a heat gun to push the fender line back. I took off that lip thing for the front on my car.
#58
your so close to not rubbing it looks like if it was a tad more in it would be fine
Wheel_Man
02-08-19 10:11 AM
Twompers
10-26-12 04:01 AM
