Metal Pedals Installed w/pics
Old 01-14-11, 08:17 AM
  #151
huy33
huy33's Avatar
Originally Posted by SteadyEddy
You guys are talking glue, not for me but there is always more ways to skin a cat.
Sorry but we don't skin cats down here in the South.
Don't forget to shorten the screw AFTER it's in the rubber piece.
Old 01-14-11, 09:29 AM
  #152
SteadyEddy
SteadyEddy's Avatar
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
What do yaull do with them? Eatem' with the fur on? lol
Old 01-14-11, 04:27 PM
  #153
mandyfig
mandyfig's Avatar
No, they take a bath on 200 degree water 1st. Then no need to skin it. LOL!
Old 01-15-11, 09:23 AM
  #154
mandyfig
mandyfig's Avatar
The angled drill is sitting in my garage. And I am at work! The pedals should have been installed by now!
Old 01-15-11, 09:24 PM
  #155
mandyfig
mandyfig's Avatar
The pedals are installed. 2 bolts on the parking brake pedal, a bit offset but 2 bolts in!
Attached Thumbnails Metal Pedals Installed w/pics-insatlled-medium-.jpg
Old 01-15-11, 09:40 PM
  #156
mandyfig
mandyfig's Avatar
The tools. Was not bad. But had to ask the good lady to install the washers and nuts. What a relief!
Attached Thumbnails Metal Pedals Installed w/pics-tools-medium-.jpg
Old 01-15-11, 09:43 PM
  #157
mandyfig
mandyfig's Avatar
Will post pics of the install to help folks who want to get into this easier. Patience worked for me. And help form the wifey who had smaller hands. She will be driving the car most of the time anyway.
Old 01-16-11, 09:18 AM
  #158
huy33
huy33's Avatar
That's one beefy angled drill.
Old 01-16-11, 12:06 PM
  #159
SteadyEddy
SteadyEddy's Avatar
Why they look almost as good as mine due!!!! lol Great job. Wasn't so bad was it? Must say you were loaded for bear, you could have drilled for days.
Old 01-16-11, 12:46 PM
  #160
mandyfig
mandyfig's Avatar
The hardest was the park brake. But was able to get 2 holes without issues with the bracket:
Attached Thumbnails Metal Pedals Installed w/pics-park-medium-.jpg   Metal Pedals Installed w/pics-parkhole-medium-.jpg
Old 01-16-11, 12:48 PM
  #161
mandyfig
mandyfig's Avatar
The brake was tricky. The 4 holes were very close to the edge. The clamps helped a lot.
Attached Thumbnails Metal Pedals Installed w/pics-brake-medium-.jpg
Old 01-16-11, 12:50 PM
  #162
mandyfig
mandyfig's Avatar
The angled drill is the only way that you can get a decent shot at locating the holes right. I broke 1 drill bit. Not bad.
Attached Thumbnails Metal Pedals Installed w/pics-brake-hole-medium-.jpg
Old 01-16-11, 12:52 PM
  #163
mandyfig
mandyfig's Avatar
The gas pedal was the easiest because of the plastic pad. hard to get the nut and washer in the back. The wifey spend 15 minutes getting the 4 nuts set up. I was lucky I had a 2.5 mm Hex wrench, none came with the package.
Attached Thumbnails Metal Pedals Installed w/pics-gas-medium-.jpg
Old 01-16-11, 12:54 PM
  #164
mandyfig
mandyfig's Avatar
I actually drilled the gas pad with the AL pedal clamped. Very carefully though so you do not damage the AL pedal.
Old 01-16-11, 12:56 PM
  #165
mandyfig
mandyfig's Avatar
Finally for the dead pad, had to add velcro and double sided tape plus the screws. The rubber tend to sink in, the double sided tape push it against the AL pad. I actually ended up with 2 layers of double sided tape to the middle. Worked well. The pad is not going anywhere.
Attached Thumbnails Metal Pedals Installed w/pics-pad-medium-.jpg
Quick Reply: Metal Pedals Installed w/pics
