Metal Pedals Installed w/pics
#107
I will be using a corded drill so I can drill away. What sizes of drill bits will be needed?
#109
Will do and will try to take pics while doing it.
#110
Bolt sizes will likely be 1/8". Harbor Freight has titanium nitride coated 10-packs that are cheap and work well on metal. I don't recall using more than 2, but it was surprisingly easy. Maybe it's because I was using a 19.2v drill.
#111
Cool thanks.
#112
#113
Just get a corded drill and slap the torque in it!
#114
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
Mandyfig I started off with a 3/32" for a pilot hole and commenced to breaking it. So I said to hell with it and went right to the 1/8" and didn't have any problems after that, as far as breaking bits. Aligning the cover to the pedal, well that was a different story, hard (time consuming, I wanted them on) but not impossible. Even if you went a little bigger or made the holes a little oblong it won't hurt. As long as you don't go too big. Don't forget to block the brake and gas pedals for ease of drilling. IMO
Good luck and happy drilling. Hope you like yours as much as I like mine. I'm even thinking about looking for a set for the ES, they look so good.
#115
#117
Finally got them on after a good hour. It helps a lot if you're only 5'4
Here are some tricks/tips that I didn't see:
- Have a cold Dr.Pepper ready and one in the fridge for when you're done. You can use beer if you want.
- Use a clamp but don't forget to tape off the tips so you don't scratch anything. Clamp the aluminum pedals so that you can use one hand for the drill and the other hand to push the pedals down.
- You can use an empty soup can instead of a 2x4 since they're about the same size.
- E-Brake is the hardest one to do. I actually took off the default rubber e-brake and fastened the aluminum on that one first. You want to widen the hole on the underside of the default rubber e-brake and then dremel the protruding screw off to where it's flush. Now just put the default rubber e-brake with the aluminum pedal back on to the metal e-brake.
- You will need a 90 degree hand drill for the top two brake screws. I thought I could do it without one but I was way wrong. I only got the bottom two screws on the aluminum brake pedal and will need to borrow/buy the 90 degree hand drill.
![](http://img200.imageshack.us/img200/5365/photo2td.jpg)
#118
Nice job Huy. They look like they belong there. Have you tried them out barefoot yet?
#119
#120
