Successful SC430 Key Programming
#241
After lots of tries (and failures) using the directions on the Forum, I contacted East Coast Locksmiths. Tami provided me with directions that were similar to those posted on the Forum, but a bit different than the ones I used. She said that, for some reason, people had problems successfully programming keys for this car. Might be timing?? Mine is a 2002 that was built in August of 2002 -- one of the last ones for that year. So, at least for this car, the dealer didn't block out key programming.
The directions follow.
Key Programming
1. Close all doors.
2. Insert an already programmed master key into the ignition.
3. Turn the key from the OFF to On and back OFF FIVE (5) times.
4. Open and close the drivers door SIX (6) times.
5. Remove the key from the ignition.
6. Insert the new key you want to program into the ignition.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.
Timing may be important. I did the key on and off to the count of 1 Mississippi, 2 Mississippi said in regular speach -- or just about on the second. Then switched keys in 3-5 seconds. Then opened the door to the same beat.
The Security light flashed for about a minute and then went out. I then hit the brake once -- proably within 3-5 seconds of the light going out.
Then started the car with the newly programmed valet key. I assume the same thing would program a new master key. Question? Can you have more than one master key? If so I may buy one and try again. Hate to lose or break the master from what I hear.
Also, here were her directions for programming the remote on the master key. Let me know if they work.
Remote Programming
1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove TWO TIMES.
3. Close and open the drivers door TWO TIMES.
4. Put key into the ignition and remove.
5. Close and open the drivers door two times.
6. Put key into the ignition. Close the drivers door.
7. Turn ignition ON then OFF ONE TIME- this will put the car in ADD mode for your remote. (Turning the ignition ON then OFF TWO TIMES will ADD the remote but will erase all existing remotes.)
8. Remove the key from the ignition. The door locks will cycle one time (or two if you are erasing) . On the REMOTE press and hold the LOCK and the UNLOCK button for 2 seconds. On the REMOTE press the LOCK button for one second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted. IF the locks cycle twice it has failed. IF this happens you must start over. Hold the remotes higher up for better reception
9. Open and close the drivers door. Put key in ignition and pull out. This will end
programming.
Thank youi Tami!!!! Saved me $80 and a big hassle. I got the key from Sewell for way less than the local Lexus dealer.
John
Key Programming
1. Close all doors.
Remote Programming
programming.
John
I ordered a remote w/ key blank from Amazon for $22.79 shipped. Got it cut last evening at the nearby Batteries Plus for $20. This afternoon, I followed JohnMD's excellent instructions and now have an operational spare.
Muchas gracias from Texas.
#242
It's nice how these old threads can turn out to be very helpful. I had an original master and one valet for my '06 that I bought a few weeks ago. Not having a spare master makes me nervous so it became the next SC mission.
I ordered a remote w/ key blank from Amazon HERE for $22.79 shipped. Got it cut last evening at the nearby Batteries Plus for $20. This afternoon, I followed JohnMD's excellent instructions and now have an operational spare.
I just bought a flip key from joemg and will be going through this myself.
Reading the instructions, it kinda felt like doing the
cheers
PinkFloyd6 (11-20-21)
#243
Key Programming
1. Close all doors.
Remote Programming
programming.
John
Key Programming
1. Close all doors.
Remote Programming
programming.
John
This is a two stage process, right? First the Key programming, then the Remote programming?
Does this process work for something other than a valet key?
Does the "Master key" described refer to one of the original keys that came with the car? Does it matter which one?
I've got four keys already for the car:
2 - standard keys
1 - wallet key
1 - valet key
Will that impact this operation?
Thanks in advance.
#244
Hi all, just bought a flip key from Joe and am trying to program it. Car is an '07 SC.
2 - standard keys
1 - wallet key
1 - valet key
Thanks in advance.
2 - standard keys
1 - wallet key
1 - valet key
Thanks in advance.
Read this thread:
https://www.clublexus.com/forums/sc4...key-101-a.html
#245
Got it all done. Helps to read the instructions.... Step 8 of the remote programming was the key. I was doing it incorrectly by pushing Lock then Unlock whereas the instructions say to press both of them at the same time.
I've now got 3 keys that open/close start the car. Don't know how that fits into the 2 Master, 2 sub keys.
Cheers,
Cheers,
#246
Cheers,
Cheers,
#247
I accidentally programmed an eBay spare key as a remote instead of a master. I've tried the master steps afterwards and the key will not start.
How do I erase the remote programming to program it as a master correctly?
#248
I bought a flip key from 1010keys on ebay a little while back, went through the steps about 20 times to program the remote part of the key to no avail, and at the same time deleted the remote on my one and only master key. Gave up, bit the bullet and took it to Toyota, they fixed the master and programed the remote and key on my new flip key.. $175... OUCH! but all works now.
#249
Do you have TechSream ? You can delete the program then reprogram it, designate it as Master key. Remember, you can only have 2 Master keys in the computer.
#250
Can you clarify your question? You got a new key, programmed the remote part of it, so it opens your door. But it won't start your car?
Now that you programmed your remote to your doors, You need to program the key to your engine.
you can try these instructions, but people don't always have luck with them
https://www.remotesremotes.com/Key-F...show=30&page=1
#253
Thanks for the writeup. I purchased a cut key on eBay from China as my SC430 had only one key. They sent the same procedure in the package but it was not working for me. After reading through the thread, the key part that was missing is speed. Gotta do it quick.
Thanks again.
Thanks again.
DshngDaryl (07-02-24)
#254
Thanks again.
Thanks again.
#255
What didn’t work?
there are two procedures.
one programs the key to start the car
the other programs the door locks etc.
did neither work?
did neither work?
