Successful SC430 Key Programming
#91
Still trying to find a key cutter other than the dealer, fyi, Lowes and Home Depot now do transponder keys but not do our type of keys. I heard maybe ACE does, I will check.
#94
Ours is a 2007. Got the uncut key from eBay (it was a real "Lexus" key). Took it to a "Li'l' old locksmith who cut it on machines that looked like 19th century. Tried the "pedal dance" and it worked after five tries. Running the procedure quickly rather than "one mississippi" work for me. In addition, I forgot to turn the spare key to "on" however after 60 seconds the security light went out anyway. The eBay key starts the car just fine. eBay $170, locksmith $25. Total $195.
Lexus dealer $560.
Lexus dealer $560.
#95
Sewell provides the service as well.
Lexus should have designed the key shells a bit better. There was a TSB on this, and yet the new shells can not last long. A re-design was in order.
The blank key is made from an insert molding process. To change the thickness to male it stronger would mean they had to make a new mold, that could easily run $100K after all said and done.
The point is a lot of us, sometime down the road will have cracked key shells. And will utter a bad word or 2 eventually. Or else use a transponder key, no remotes. Then your keyholes will be scratched big time. No win.
Let's do a push start DIY...
#96
I used the old key shell with remote removed and put in in a magnetic Hide-a-Key box and hid it under the car. It will unlock the door and glove box but it will not start the car.
I then put a non-remote (already programed) key, well hidden, in the trunk. That key only cost about $45 precut to my vin by Sewell Lexus.
To steal the car you have to find two well hidden keys.
If I loose my key I won't be stranded.
JR
JR
#97
Lexus dealer $560.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Lexus dealer $560.
I bought keys from Sewell Lexus precut to my vin. I bought one key shell ($70) one remote master key ($188) and 2 non-remote transponder keys ($47 each) from them. I then took 3 precut keys the to my local Lexus dealer who programmed the 3 keys for $60 = 1/2 hour labor. So for a total of $430 have one empy key shell and 5 programed keys, including the valet key, for each SC430.
To add; local dealer would only program Lexus Brand keys purchased from a Lexus dealer. They would not program 3rd party keys. Their normal programming fee is $60 for 1 key and $99 fir 2 or more. They charged me me the $60 single key programming fee as a curtesy
For my 2nd SC430 I wanted a cut but unprogrammed key to put in a Hide-a-Key box. I bought 2 key shells on eBay for $14 and the local Ace Hardware cut it for $25.
JR
#98
When i bought my Lexus, I received two remote keys, one valet key, and a wallet key card with built in transponder. None, to this day, have broken. Knock on wood. I always keep the wallet key in my wallet just in case. I didn't feel too safe leaving a hide a key, just in case i ever have it up for service or mod work and someone spots it. Now on my Chrylser Sebring, I was hoping someone would steal it so I kept a hide-a-key behind the gas reservoir and the doors unlocked. :-)
#99
It’s a habit I picked up from flying. On my aircraft I always hid a key taped to the inside the wing. To get to it you would need to remove an inspection panel with a Phillips screwdriver and reach inside the wing behind a rib to get to the key. You could only see it with a mirror so you would need to know exactly where it is and feel for it. It gave me a warm sense of security, especially when traveling to the Bahamas. Loose your keys there and it’s a long swim back home.
JR
#100
One of my Sc430s only came with a single master key with a worn out key shell and a valet key.
JR
JR
#101
Cost was either $25 or $29 to cut the key. Not cheap but convenient.
JR
#102
Just my luck, the one ACE near to me might not be able to...I shall see.
#103
$25 + $3 for the shell, less than $30 and have a set of brand new remote key, not bad at all.
#104
Sorry I did not see this stream earlier. I just went to the local lock smith. He actually has blanks, but will also cut wallet keys and blanks bought on line. I also saw a vendor on eBay that would sell 2 switchblade keys cut for one vehicle with space for a remote - you have to supply that - for $45. I asked if you could get different cuts, and they said the cost only covers time for one
