Successful SC430 Key Programming
#106
Still no joy on programming a third key into the wife's 02 SC430. I've done the 5x key start, 6x door open/close procedure numerous times, and the only thing I've noticed is when I place the un-programmed key into the ignition, i get this;
The security light blinks once per second for around 10 seconds, then the cadence changes and it does two quick, one short blink, followed by a pause. I left the key sit in the ignition and watched this continue for almost 5 minutes. Still not programmed. I can only presume there is some activity as the blinking changes.
I got two keys from the seller, one with a 3 button remote that has never locked/unlocked the doors, but does start the car. The other is an aftermarket ILCO key which starts the car but has no remote buttons.
Please Help! Marty
Please Help! Marty
#107
Not sure if 02 and 08 are same but think they are.
I had to try several times (maybe four?) before success. I also discovered that a rapid sequence worked not the "one Mississippi.....etc" as suggested. My failures were with the slow cadence, my success was with a rapid cadence.
I successfully programmed three start and remote function keys this way (with a little bit of patience and lots of determination). I got all three (original Lexus) programmable blank keys from eBay and had them cut at a local locksmith using my one and only master key. Hope this helps some.
#108
I know this is an old tread however, two of my key's housing broke on my 02 SC430 and I bought the flip to side keys from ebay. I paid $29.95 at the dealer to get one of them cut, however, the new key won't start the car although I swapped the remote from the old working key. Is there like a small transponder or something in the old keys because when I put one of my original keys by the ignition and try to start it with the new key it works!
#111
TBH, i'm not sure what it looks like in the OEM key. I removed mine from the wallet key to put in my LuxLink. It was small and black and flat. Smaller than an quarter. It looked like a plastic chip. Maybe another member can shed some more light on how to remove it from the OEM key to put into your side flip key.
Check out this pic....http://galleryplus.ebayimg.com/ws/we.../1000x1000.jpg
#112
#113
The "transponder" is part if the remote push button guts installed in the OEM master remote key shell. It is not separate.
With the flip key perhaps the transponder is not close enough to the receiver in the car key hole to activate it.
Try swapping the remote guts between your working key and the new flip key and see if the problem stays with the flip key or moves.
#114
http://www.ebay.com/itm/TOPQ-FLIP-FOLDING-SMART-REMOTE-KEY-FOB-CASE-SHELL-for-Lexus-3-BUTTONS-/200953099273?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec9bcf409&vxp=mtr
#115
I considered the flip key but reading some negative reports and trying to get it cut locally I decided to buy a new OEM remote key shell form Sewell Lexus. They get $87 for the OEM key cut to your car if you provide the VIN Number and proof of ownership.
I used the old broken empty key shell and hid it in a magnetic Hide-a-key holder on the under-frame of the car. I then hid a fully programmed working key in the trunk.
JR
JR
#116
Key Replacement Experience
My experience ... I have a 2004 SC430
Purchased a three button remote key from this eBay seller: http://www.ebay.com/sch/motorshops/m...1&_ipg=&_from=
Priced at $79.99 plus $3.50 shipping. (Sometimes he has them in stock, sometimes not.)
It was advertised as new. It arrived in just a couple of days. It was brand new with battery and of very high quality. It may have been a Lexus product.
Took the key to my local ACE Hardware where they cut it for me. Charged me $5.00.
Brought the key home and programmed the remote functions and start functions as detailed in this post. Worked perfectly.
Total cost: $88.49
Thanks Club Lexus Forum!
Total cost: $88.49
#117
After biting the bullet and paying for a new master from Sewell Lexus I'm trying to program it without success. I plan to go at it again today but have a couple of questions. How should you lock the door? With current remote or manually from inside the car? Do you use the old remote for all the procedures until it comes time to hold down buttons on new remote? The security light seems to be on while I'm in the car. Is this ok? Thanks!
#118
OK, when I received the master key from Sewell it would start the car but not open or lock remotely. Now, after following the directions on this forum it won't even start the car! I probably screwed things up by messing with the Key Programming sequence but I had tried the Remote programming many times with no success. The locks never cycled as predicted in the write-up. Unless someone here has some good advice I will have to go to a Lexus dealer to get this programmed. Hopefully, I didn't do any lasting damage to the key which was over $200!
