Thanks to Lee
Thanks for the info everyone!!!
I had the calipers painted red (they were black). I am ready for final purchases.
Check list:
Do I use the SC430 Pins from my car (long bolts, 2 on each side) or do I need Supra TT OEM Pins?
Can I use 13" rotors, or stay with 12" stock size rotors?
Shuold the rotors be ordered for SC430 or Supra TT?
Should the Pads be ordered for SC430 or Supra TT?
Should the brake lines be ordered for the SC430 or the Supra TT?
Check list:
I USED THE SUPRA TT BOLTS
13"
YES!
YES!
I USED TOM's BRAKELINES FOR THE UZZ40, but the SECURE SPIKE of the brake line (don't know what this is called in US language) which attached to the calipers pressure line/flange won't fit (resolved this by rotating to a secure position). So i am unsure if the SUPRA lines are to long or to short for the SC!?
regards
marcus
13"
YES!
YES!
regards
marcus
actually to be exact i think the supra rotors are 12.7". definitely make sure you get the rotors and pads for the supra tt, no more sc430 setup ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
from my understanding the supra lines are too long. you should get the lines for the sc430. for example my ap racing brakes for the gs400, it was designed for supra. when i got the kits, the lines were too long for the gs400, so i used the ss line for gs400 and fit no problem. the sc430 is very similar to the gs, so the same case should apply
marcus
marcus
My Supra TT calipers did not come with the bolts.
Were they supposed to?
Anyone have Toyota part number for:
The Pin Kit?
Shims & Carrier Kit?
Have I missed anything?
43516-14030 ROTOR D. 323 mm
43512-14200
47730-14260 CALIPER
47750-14270
04465-14390 PADs
04945-14120
47748-14080 SPRING
47789-14010 SPACER, DISC BRAKE
47799-14010
90105-12175 BOLT
regards
marcus
43512-14200
47730-14260 CALIPER
47750-14270
04465-14390 PADs
04945-14120
47748-14080 SPRING
47799-14010
90105-12175 BOLT
regards
marcus
43512-14200
47730-14260 CALIPER
47750-14270
04465-14390 PADs
04945-14120
47748-14080 SPRING
47799-14010
90105-12175 BOLT
regards
marcus
43512-14200
47730-14260 CALIPER
47750-14270
04465-14390 PADs
04945-14120
47748-14080 SPRING
47799-14010
90105-12175 BOLT
regards
marcus
Last question: what quantity for each item above?
well i think each number stays for 1 item... i can't verify this from invoice at the moment. so you should order the numbers at your local dealer and have an eye on his EPC system...
please note those numbers stand for the european supras. might be different for the US parts...
regards
marcus
regards
marcus
The TRD (Supra TT) Front-Brakes are finally installed. "Thanks to Lee" and to a fellow Florida CL member, I have completed one of three mods scheduled for this week. Dave, a fellow member and good friend performed the actual install on sunday. It was a good learning experience for me. I will finish them with TRD badging just waiting for the decals. Here are a few pics;
Brembo Rotors:
Before...
After
SC430 Stock Brake:
Heat-shield Before...
![](http://sanfordhelpdesk.com/images/7-2-06_3.jpg)
Heat-shield After
![](http://sanfordhelpdesk.com/images/7-2-06_4.jpg)
Reference to TRD Brake Kit ; Link
Brembo Rotors:
![](http://sanfordhelpdesk.com/images/7-2-06_6.jpg)
Before...
![](http://sanfordhelpdesk.com/images/7-2-06_1.jpg)
After
![](http://sanfordhelpdesk.com/images/7-2-06_5.jpg)
SC430 Stock Brake:
![](http://sanfordhelpdesk.com/images/7-2-06_2.jpg)
Heat-shield After
![](http://trdparts.jp/english/image2/p_highperformance.jpg)
-Does the TRD kit include the rotors? If not, did you buy those from an authorized Brembo distributor, or are those from Ebay?
-How much for the TRD kit plus the rotors (if separate)?
-How did you cut the heat shield?
-Did you just bleed the brakes normally after installing new lines? I need to bleed my brakes since it's been 3 years (although fluid still looks perfectly clear), and want to make sure there's no special procedure with the separate accumulator pump.
Man, those stock brakes look like a joke, especially with bigger wheels. Take care, and thanks in advance for your help with my questions.
Originally Posted by ELP_JC
Looks great man. A few questions, if you don't mind:
You'll have to search online for the TRD kit - I think they do come with rotors, I think Carson Toyota has them. I did not buy that kit. That kit has different fitments to different toyota and lexus models. Always confirm fitment with seller.
Ebay
I did not buy the TRD Kit. I bought the parts to create my own front brake kit. Expect to pay around:
($500 for a pair of New Calipers from Carson Toyota)
($150.00 for a pair of Drilled Slotted Rotors from Ebay)
($100 for a set of 4 Steel Braided Brake Lines from Tirereack)
($70.00 for a set of 4 Brake Pads from Tirereack)
($100.00 for shipping and any extra parts, fluid, etc.)
($920 "more or less" for all parts delivered to your door) Plus labor.
With a pair of Shears for cutting metal. Dave (2jznat ) made it look easy, he is quite crafty.
Yes normal bleed procedure.
Ebay
dvdchance
06-27-14 03:17 PM
0494514120, 4774814080, 4779914010, brake, brakes, content, gs300, injen, installl, intake, rotor, sc430, size, supra, trd
