New Work wheels fit TPS
I just got my new Work wheels I ordered from Derrick of D2Autosport mounted today. The wheels have 2 tire stem holes. The outer one is the usual 90 degree fill stem that is usually with the wheel to allow for the wide flat lip. However there is a second hole on the inside lip on the 45 degree stepped surface for the tire pressure sensor unit to mount. Good idea. One could easily copy if you had the fortitude to drill a hole through your expensive rims.
Originally Posted by tonydt1g3r
dont drill thats just stupid get the bands, mine have been working flawlessly
though personally, honestly? i might prefer drilling (done professionally)
Here is another photo, slightly out of focus, but with the TPSM mounted on the back rim with the stem fitting backwards. In the distance there is the normal hole for the 90 degree valve stem that goes out the front. It is lying on the rim.
wow damn, even for lexus? that's nice. what work wheels is that? thanks for the pics!
so it's specifically for wheels with tps huh? and for others i guess there won't be such a hole huh
Its is such an easy and good idea. I think it would be very easy to drill out the hole to put in the TPSM and if at a later date you didn't want it I don't think it would not be hard for a wheel shop to weld it closed. With it on the back it wouldn't show.
